Sami is sick
Sami is sick
wheresmyhat
244
16v here I come baby!!!
Sami is sick
March 31, 2006, 06:46:10 PM »
Sami is cutting out alot and no top end speed. Pulling the plug wire on number 1 affects the motor a little. Pulling plug wire on number 2 does not affect it at all. In fact i can have both off and the engine runs about the same. Compression check shows 180 across the board. I have spark at each plug and even swapped plugs around in case there was one bad.
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
okezuki
51
Re: Sami is sick
March 31, 2006, 07:32:25 PM »
try swaping the wires from the good cyl. to the bad. if it follows ,the wires are bad. caps can also cause this problem
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
wheresmyhat
244
Re: Sami is sick
March 31, 2006, 08:04:05 PM »
replaced the cap and rotor this morning. swapped the wires but still same result. Any more suggestions
Toy Box
222
00 Grand Vitara
Re: Sami is sick
Reply #3 on:
March 31, 2006, 08:32:00 PM »
Check your spark plug wires ;
You Play you Pay
wheresmyhat
244
Re: Sami is sick
Reply #4 on:
April 01, 2006, 09:17:27 AM »
The wires are about 8 months old plus I swapped them around and still had the problem with the same cylinders. And if you do it at night you can defenitely see the spark.
takai
907
Yes, I drove that here. And No, it's not done!
Re: Sami is sick
Reply #5 on:
April 01, 2006, 10:16:24 AM »
Where is your timing at?
97 Tracker "Jezebel" Bone Stock DD
'Cause, I am to misbehave.
wheresmyhat
244
Re: Sami is sick
Reply #6 on:
April 01, 2006, 05:33:11 PM »
Timing is at 10 degrees. Did it yesterday.
