4" suspension lift
  • 1 Replies
  • 1221 Views
Offline CDAVIS00346
  • 87 sammy
4" suspension lift
« on: February 26, 2004, 12:49:25 PM »
i just bought the 4" suspension lift from roadless gears with bds shocks and the crossover to help with bump-steer.  it just want to know if i am going in the right direction.  is this the way to go?  i am new to this and want to learn from your guys and gals mistakes ;D.  so if you have any suggestions please help a brother out.
thanks, clark
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: 4" suspension lift
« Reply #1 on: February 26, 2004, 01:50:09 PM »
Welcome aboard! I have the BDS 4" spring and shock combo too. I've had it for about 2 years now and since replaced the rear springs and the shocks. The passenger side rear spring broke in half but thanks to the military wrap design they held together so I could drive home. BDS covered the cost of the spring under there "You break it we'll replace it policy". The shocks didn't give me enough travel so I bought some 32" DoetschTech shocks.
 If you plan on doing some serious rock crawling and you gear down your t-case I strongly recomend a traction bar to stop the springs from warping.
Good luck with your lift. You'll like the results.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
