Fitting 31's - ProComp Deal...
  • 1752 Views
Offline Z71Edge
  • 87
« on: October 01, 2008, 07:27:14 AM »
Im looking into ordering some spacers soon from Jeff. And then I was thinking for tires I was going to run either 30's or 31's on stockers...eventually get some 1-1.5" wheel spacers to bump the stock wheels out. Anyways, ProComp is offering the "Buy 3 get 1 Free" deal and I really like the Extreme A/T tires they have...they look like a good all around tire, plus they have decent voids between the lugs to help clean out in the mud. I can basically get all 4 for about $400...and my local 4wheelparts said they would mount and balance them for free. The question I have is will I be able to fit these on my stock wheels with the 2" Spacer Lift? The 235's I have now have no problem with clearance and I have no lift. Here is a link to the tires Im looking at. Thanks!  8)
http://www.4wheelparts.com/Tires/Pro-Comp-Xtreme-All-Terrain-Radial.aspx?t_c=13&t_s=157&t_pt=100809&t_pl=3360&t_pn=PCT55031
« Last Edit: October 03, 2008, 05:46:49 AM by Z71Edge »
93 Tracker, 1.6L 5spd, 235's on stockers for now...
Re: Fitting 31's - ProComp Deal...
« Reply #1 on: October 01, 2008, 09:17:54 AM »
It would be tight, but with some fender trimming it would probably work.  If you need to you could throw a 1" body lift on as well.
The 10.5" will fit on a 7" wide tire.  That's about the widest you want to put on it though.
I would go with 1" wheel spacers instead of the 1.5".  The 1.5 stuck my 28.5" Toyo Tires out to far and they would rub the back of my fender all the time.
Offline jeff1997
  • 1228
  • 27
« Reply #2 on: October 01, 2008, 01:26:10 PM »
I agree with drone367. They will fit with a little trimming but you will have to drive easy until the lift. The width is fine, I run 11.5's on factory 7" rims. I also have 1.5" wheel spacers and they are a little wide. the 1" would be better, less wear on wheel bearings too.
3" Masterkit1 body lift
Custom strut spacers
Offline Z71Edge
  • 87
« Reply #3 on: October 03, 2008, 05:47:39 AM »
Thanks for the help guys!  8)
