Sammy Trac Bar
  • 10 Replies
  • 3014 Views
mudfkr
Sammy Trac Bar
« on: January 31, 2005, 05:22:43 PM »
Hi All,
I'm currently building a trac bar for my mates SPOA Sammy and I have never seen a Sammy with a trac bar  so I'm kinda  guessing how it should be mounted etc.
So can those who have some knowledge  in this(hell even those that don't why not chime in too ;D)  have a look at my axle bracket and let me know what you think.
We're thinking the bottom hangs down to low and I need to bring it up to level with the bottom of the axle to stop it fouling on rocks etc ?
What ya all think ?
« Last Edit: January 31, 2005, 05:23:54 PM by mudfkr »
Offline mrfuelish
  • 2862
Re: Sammy Trac Bar
« Reply #1 on: January 31, 2005, 05:44:22 PM »
Ya, I would go up 2.5 inches or so.
Offline supazuk
  • git 'er done!
Re: Sammy Trac Bar
« Reply #2 on: January 31, 2005, 09:19:17 PM »
not to jack the post but where did you get the cross drilled rotors?
shut up and wheel it.. sick of hearing oh my (fill in blank) stock can climb mountians yet the only off roading its seen is the curb their g/f ran over!
  • 6589
Re: Sammy Trac Bar
« Reply #3 on: February 01, 2005, 12:52:41 AM »
Nah, don't worry about that amount of hang down. You're going to have a huge long ramp leading up to it and it'll protect your driveline...
'Sides if you go up past the centerline of the axle it will not work as well.
HTH -Eric
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: Sammy Trac Bar
« Reply #4 on: February 01, 2005, 12:54:20 AM »
taht is one way to do it i usually just use a leaf spring axle perch make a ladder bar and a crossmemdr for the top and conect it with a jonny joint to the cross member and 2 ubolts on the spring perch. if u use that bracket it has to come up past the bottom of the axleor make a nice little skid plate for it.
« Last Edit: February 01, 2005, 12:54:55 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline HUMZUKI
  • 117
  • Fool!
Re: Sammy Trac Bar
« Reply #5 on: February 01, 2005, 01:40:56 AM »
I was going to buy this one but I might just make one. Damn good price though and looks solid.
http://www.angelfire.com/rock3/phoenix3/bar.html
Offline tracker8wr
  • 568
    • my home page
Re: Sammy Trac Bar
« Reply #6 on: February 01, 2005, 04:09:10 AM »
I'm not a big fan of hime joints any more i put a lift on my XJ and it had hime joints they work great off road but for on road everyday use the wearout and rattel. it gettes very anoying. i replaced them all with johnny joints the main diferance is the hime is incase by steel the johnny is incased by polyurithane.
this is refering to ur site with the trac-bar for sale
« Last Edit: February 01, 2005, 04:09:54 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
mudfkr
Re: Sammy Trac Bar
« Reply #7 on: February 01, 2005, 05:29:03 AM »
They are standard solid Sammy rotors that we just cross drill  ourself. Nothing special about them just make a template to fit over the inner with the drill pattern (find an old road bike front disc to fit over it  ;) ;)) you want and drill away. But make sure you drill a R/h and L/h set as they must be directional like the one you see in the pic otherwise all the girls will want to be in your Sammy when you put the brakes on  ;D
mudfkr
Re: Sammy Trac Bar
« Reply #8 on: February 01, 2005, 05:34:15 AM »
HTH -Eric
I was thinking that myself,
I'm of two minds here, from an engineering perspective it should be either side of the axle but from a wheelers side of things ground clearance is the go.
As it my mates rig I'll pass on the info to him and he can decide which way he wants to go from there.
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
Re: Sammy Trac Bar
« Reply #9 on: February 01, 2005, 07:04:56 AM »
Don't quiet get it, could you post a picture of what you mean ?
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: Sammy Trac Bar
« Reply #10 on: February 01, 2005, 01:44:18 PM »
I made mine about even with the bottom of the axle tube. By having it hang down like you do, you lose the offset housing/drivetrain advantage. on the other end (front) I used a shackle that put the traction bar end in line with the two spring mounts. I now keep my springs together and didn't lose any articulation. I'll try to get a pic.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
