truck is sagging
  • 7 Replies
  • 2361 Views
Offline derekj
  • 784
  • i'm the canadian guy eh?
truck is sagging
« on: December 29, 2005, 07:15:32 PM »
so here we go - the left front of my truck sits 1/2" lower than the right(measured at the frame). the left front would always bottom out way easier than the left. i have the bds suspension lift in my truck so i got a new set of front springs under warranty. i just put them in and the truck still sits 1/2" low on the left. i have gone thru the front end and nothing is bent or broken. my  question is - is the truck supposed to sit a bit low on one side? i never measured it before i put the lift in.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline mrfuelish
  • 2862
Re: truck is sagging
« Reply #1 on: December 29, 2005, 09:08:11 PM »
Did the springs look the same when out of the rig? I put a 2" old man emu spring lift in a buddys heep and they were a little bit off so I put the longer ones on the drivers side, they give you some yellow polly looking shims to put underneath the springs if they are off but they are only a 1/4" thick or so, I was not taking the springs back out for a 1/4" diff you might have to shift some weight around.
Offline derekj
  • 784
« Reply #2 on: December 29, 2005, 10:43:08 PM »
i have the old bds springs and the original suzuki springs sitting on my work bench. the bds ones are the same height and the factory ones are 1" shorter. i think i might just try and find a thin shim for the top of the coil spring but i might try swapping the springs from left to right.
derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #3 on: December 30, 2005, 05:43:27 AM »
Just a suggestion, but are both of the factory isolators in? Sounds like it's missing on the left side. They're about 1/4" thick and could result in about 1/2" diference.
Offline derekj
  • 784
« Reply #4 on: December 31, 2005, 04:55:26 PM »
so i took out the new bds springs and but my original bds springs back in but i swapped them left to right. now the front sits level - go figure ??? i looked all thru the instructions and nowhere does it say that the springs have a left and right....oh well problem solved.
derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: December 31, 2005, 05:15:37 PM »
derek
So,... do you now have a set of front springs for sale  ;D ;D ;D or do you need to return them  :(
Offline derekj
  • 784
« Reply #6 on: December 31, 2005, 05:31:22 PM »
i have to phone them on tuesday but either way if you want them they are yours. i have the complete front kit (alignment adjusters, strut extensions) also.
derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
Offline derekj
  • 784
« Reply #7 on: January 02, 2006, 07:44:57 PM »
sent you a pm uncivilized
derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
