what years of ford rims fit trackers?
  • 12 Replies
  • 10443 Views
Offline delorean
  • 8
« on: June 10, 2007, 07:38:20 PM »
could someone tell me what ford rims work on a tracker, i have a 1991 tracker and i want some steel wheels for 15 inch mudder tires. thanks
Offline jeff1997
  • 1228
  • 27
Re: what years of ford rims fit trackers?
« Reply #1 on: June 10, 2007, 08:08:19 PM »
I do not know what years fit but I have a set of 4 I'd like to get out of my garage. I live in IL, so if you are remotely close we could work something out. They are 15x7, have no rust and no bends.
3" Masterkit1 body lift
Custom strut spacers
Offline sidekick 4x4
  • 97
  • sidekick
« Reply #2 on: June 11, 2007, 02:50:03 PM »
where do you live in IL because im looking for some rims
1990 sidekick,snorkel, 2.5" coil spacers, procomp shocks and strut extenders, 3" calmini body lift, 30" A/T,CHEERY BOMB MUFFLER
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: June 11, 2007, 03:46:15 PM »
I live in Highland, it is about 30 miles straight east of St. Louis
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: June 11, 2007, 07:53:43 PM »
OE ford wheels wont fit without having the center machined out to 4 1/2 inches. Ford does have the same bolt pattern so aftermarket wheels do fit.
Mike
Offline olija
  • 770
    • Check out my cardomain
« Reply #5 on: June 11, 2007, 10:01:37 PM »
How would you go about machining out the center holes? Just use a hole saw or what?
Also, nobody has said what year of Ford rims work yet.
« Reply #6 on: June 11, 2007, 10:15:25 PM »
Most Ford 1/2 ton  truck AfterMarket Rims
The Stock ones centers are too small.
Jeep CJs (what ever years had the 5 on 5 1/2 boltpattern)
I don't know heeps, they all look alike from my house.
81-93 Dodge 1/2 ton Trucks
« Last Edit: June 11, 2007, 10:20:02 PM by HotRod »
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #7 on: June 12, 2007, 07:17:56 PM »
Try looking in the salvage yards for Ford Bonco (fullsized!) aftermarket wheels.
They are the spoke type and the center hole is large enough to work.  I have 5 on my truck.
Also:  do a search for wheels for a comprehensive list of interchangable wheels for the Samurai/TracKick.
Hope that helps!
Ack
Offline jeff1997
  • 1228
  • 27
« Reply #8 on: June 12, 2007, 07:29:59 PM »
Mike
[/quoteThe set of OE Ford rims I have fit perfectly, the center holr is exactly the same size as stock Suzuki rims-118mm?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #9 on: June 12, 2007, 07:43:20 PM »
I was under the understanding that Ford rims don't need modification as long as they're the 4WD rims, and not the 2WD rims. I'm sure mine are from a Ford F150 4x4, but they look similar to a Jeep CJ wheel.
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #10 on: June 13, 2007, 08:27:30 PM »
I belive its 97 and older and even the 4x4 option the center holes are too small. I had a set of wheels off a ford that I had the centers cut out on a lathe. Again I am talking Factory wheels. Aftermarket Ford wheels bolt right on.
Mike
Offline bus_driver
  • 479
« Reply #11 on: June 14, 2007, 10:32:30 AM »
you also have to look at the off set i got a set of early 90's f series and the off set was too much and would of rubbed more than my stock rims.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline jeff1997
  • 1228
  • 27
« Reply #12 on: June 14, 2007, 04:20:33 PM »
Mike
The FACTORY rims I have from a Ford truck have the proper hole size and bolt pattern.
