Samurai Questions
  • 1579 Views
kawasakikid
Samurai Questions
« on: April 11, 2007, 04:01:54 PM »
Well I just bought a 88 Samurai that is bone stock.  I wanted to get some info on it such as what size ring gear in the rear and such.  Also what would be a good start for a lift.  I didt know if going with the SPOA would be the best and keep the stock springs or with the jeep springs.(not sure what model)  Thanks Phillip
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
Re: Samurai Questions
« Reply #1 on: April 11, 2007, 04:31:51 PM »
Congrads on the new sammi. Stock ring and pinion is 3:73's
Lift all depends on what you are looking to do with it.
Yj were produced from the late 80's to the mid 90's and came with spring packs with 4, 5 and 6 springs per pack. Usually you will find a stock set consisting of two 5 spring packs and two 4 spring packs.
Anything over a 31" tire and you will be looking for gears.
I will say that there is deffinetely a lot more vendor and private support and products for the samurais and tracker/sidekicks now then there was 10 years ago so your options are unlimited.
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
kawasakikid
« Reply #2 on: April 12, 2007, 07:19:32 PM »
Alright well I guess this would be another dumb question, we have a 78' CJ-5 and just bought new 4'' lift springs, would these by chance fit, didt know if it only could be the YJ springs
Offline costa 05
  • 206
« Reply #3 on: April 12, 2007, 10:03:09 PM »
Do ya own a torch and a welder, they'll fit. >:D
when in doubt gas it!!
« Reply #4 on: April 14, 2007, 08:13:41 AM »
Moving the Rear Spring Up Front and putting the front CJ springs in the rear has been done a few times.  I know someone out there sells a kit...
