samurai tach
samurai tach
slamurai
samurai tach
September 22, 2008, 07:57:49 PM »
can anyone tell me the wiring i need to use in order to wire an aftermarket tach in a 1994 Suzuki samurai with fuel injection. it did not have a tach in it when new. thanks
Drone637
8121
116
Evil Cow
Re: samurai tach
September 22, 2008, 09:11:00 PM »
The tach you picked up should come with some instructions, It will connect up to your coil, quick and easy.
Merlin93
170
4
Re: samurai tach
September 25, 2008, 08:20:42 PM »
... wire an aftermarket tach in a 1994 Samurai... ?
For a SunPro 2 5/8" tach -- 4 wires: +12V, +12V dash lights, ground, ignition coil (Brown/White) on my '93. Fits perfectly in a 2.5" hole. Held in place with a bead of clear RTV around the mounting ring before insertion.
sabum
Re: samurai tach
Reply #3 on:
June 09, 2010, 03:39:10 PM »
i have a 1994 samurai, i am putting a tach in, will the wiring be the same. can anybody show me a picture of the coil and the wiring, i have tried and i cannot get it to work . thank you.
fordem
4333
170
Re: samurai tach
Reply #4 on:
June 10, 2010, 09:14:44 AM »
The wiring will
probably
be similar, and the only way to be certain is to get the manufacturer's instructions
Haptown
Re: samurai tach
Reply #5 on:
June 10, 2010, 05:30:22 PM »
Here is a link to a image that i have from my 91 EFI. The blue wire (should be green on most) is from the tach and it connects to the brown (middle) wire on the connector. Just splice it in as the brown wire is still required by the ECM.
Tach-to_coil image
Last Edit: June 10, 2010, 05:35:59 PM by Haptown
