samurai transmission wires
  • 3583 Views
Offline suzsami
  • 41
  • 1987 Samurai
« on: October 20, 2003, 01:18:43 AM »
    There are fuor wires coming out of my transmission two per plug , it looks like the plug go into the eng compartment and connect to each other , well I tore one set of wires out it looks like they connect to each other , does anyone know what if anything I need to do ?
  • 6589
Re: samurai transmission wires
« Reply #1 on: October 20, 2003, 01:38:56 AM »
One set is for your reverse lights the other is for 5th gear. When in 5th, the computator doesn't recirculate the egr gasses. (I think.) Can I get a confirmation? :)
Offline suzsami
  • 41
  • 1987 Samurai
« Reply #2 on: October 20, 2003, 06:37:33 AM »
Well I but have not had any revers lights before cause they were hooked together .. I will look again to make sure ... thanks for the repley ...
jdraper
« Reply #3 on: October 21, 2003, 12:19:55 PM »
You got it Eric,  there is a 5th gear egr lockout switch that should have 2 wires.  One is black and goes to ground, the other is Light Green/Red and goes to the ECM.  Your reverse light switch should have a yellow wire and a red wire.
