sas into 90 sidekick what axles to use?
  • 10 Replies
  • 2929 Views
« on: August 14, 2008, 05:02:05 PM »
I am going to do a solid axle swap into my sidekick. I can get any axle i want so i want to talk to someone that has done this before. The toyota axles are close to stock widh but how many parts do you break with the stock motor? I plan on upgrading to a 4.3 in the future but i am not sure if they will hold up? Should i use a dana 44/ dana 60 combo? Or go with full size chevy 10 bolts? The only thing i am looking at is the avalibility of parts for the american axles. Thanks
Re: sas into 90 sidekick what axles to use?
« Reply #1 on: August 14, 2008, 05:21:41 PM »
More details...
2/4door
Stick / Auto
Final tire size
Your driving style
Conditions vehicle will be driven in
What's your breakage tolerance?
Normally I'd recommend Toyota, as they're easier to adapt. But, if you're going with a 4.3, you may want to consider a Dana 60. It's stronger than a beefed up yota, and you have room to grow.
Why a 4.3? You're going to add a lot of weight up front & raise your CG.
« Reply #2 on: August 14, 2008, 05:36:28 PM »
2 dr
stick
33" - 35"
hard
michigan mud and hills
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« Reply #3 on: August 14, 2008, 06:12:23 PM »
i live in michigan and the mud suck compared to down south.  Were i live there is a lot of clay in the dirt.
« Reply #4 on: August 15, 2008, 02:35:53 AM »
If you're thinking 35", and wheeling hard... you'll want upgraded Toy axles. You can build Toy axles to be as strong as Dana 60, but it'll cost you 2x as much and you'll be maxed out. Stock Dana 60 will be cheaper, and you can always upgrade. And, Dana will give you much better turning rad. If you were a mild wheeler with 33", I'd say toy.
« Reply #5 on: August 16, 2008, 06:32:13 PM »
today i picked up a ford nine inch rear and a chevy dana 44 front
« Reply #6 on: August 17, 2008, 11:53:27 AM »
Keep us posted
Offline Luke
  • 43
« Reply #7 on: August 19, 2008, 04:59:42 AM »
You must have been joking when you said 10 bolt. :laugh:
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #8 on: August 19, 2008, 08:41:20 AM »
I'm in Michigan also.  It's almost a must to have a snorkle to make it out alive.
What did you get the 9" out of?
96 Tracker
32 MTR's Warn 8000i
« Reply #9 on: August 19, 2008, 04:37:09 PM »
i got the nine inch out of a 75 f-150  i got the pair of axles for 40.00 from the scrap yard
« Reply #10 on: August 19, 2008, 04:39:39 PM »
i have a pair of 10 bolts in my mud bogger its a 95 s10 i put richmond 5.13 in them and welded the spiders and never broke any thing yet. i have a 355 with 400 horse and a 3500 stall converter
