Searched but
Searched but
sammykicked
I love YaBB 1G - SP1!
Searched but
January 13, 2005, 11:47:55 AM »
Was unable to locate.
We are building an 83 Sammy but putting in a newer
motor from a newer sidekick.
Going from 1300 to a 1600 16valve but cant get it 2 fire.
No spark.
Is there something we are missing? Any schematics out there for this conversion?
Sorry but this is the first ZUKI project ever.
Been a offroader for years with Jeeps
Thanks so much in advance.
Electrically challenged
92Sidekick4x4
1456
Spencer Atkinson, 92Sidekick4x4
Re: Searched but
January 13, 2005, 12:27:30 PM »
ummmm could have something to do with the ECM, check all your fuses, hopefully its not your ecm, they suck, also check your o2 censor and fuse, check the ignition fuse thats the problems ive had with mine when it wouldnt start
my lug nuts require more torque then my engine makes
mrfuelish
2862
13
you must have a perception problem.
Re: Searched but
January 13, 2005, 01:41:25 PM »
That's kind of a highly guarded secret around the web,there are venders on here that used to charge 400.00 for that, you can get them now for around 200.00 all marked and ready to go. try trail tough. and give us a little more info if you think your close to getting it.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
wildgoody
8134
67
Re: Searched but
Reply #3 on:
January 13, 2005, 02:50:58 PM »
What do you have swapped ?
Did you get the ECU ?
The distributor in a 16V has a pickup,
no points, so if you don't have the electronic
ignition stuff, it will get no spark
Details are what answers are made of
idaholwb
772
2
And that's the way the metal crumpled!
Re: Searched but
Reply #4 on:
January 14, 2005, 07:56:24 AM »
83 sammy?? I thought the 83 model was an SJ410.
97 Sport
265/70-16s
2" lift
2.0 swap
