SGV stops when steering left or right on 4H during
  • 2130 Views
Offline sandriver
  • I love YaBB 1G - SP1!
« on: February 28, 2005, 08:45:08 PM »
I can park my grand vitara easily on 2H; but when I shift 4WD it gets hard to maneuver while parking.
Do all 4WD's have the same problem?
or Suzuki GV only?
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: SGV stops when steering left or right on 4H du
« Reply #1 on: February 28, 2005, 09:01:30 PM »
Put ARB's front and rear, and turn them on - Great traction, as long as you don't want to TURN!
Yeah, my wife's GV chirps the tires turning in 4WD as well.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #2 on: February 28, 2005, 09:43:55 PM »
Better not to drive in 4wd on the pavement, your front drivetrain will wear very quickly becaus there's no diff in the t-case.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
« Reply #3 on: February 28, 2005, 11:24:06 PM »
Yes ANY 4x4 will handle and steer different whan you have in in 4wd, even in bone stock form. It becomes even harder when you are operating 4x4 on dry pavement due to the drive line binding up (and you can damage your vehicle making tight manuvers in 4x4 on surfaces with good traction).
HTH,
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #4 on: March 01, 2005, 03:38:04 AM »
Yeah just think about this the inside tire is only tuning at say 1 full turn and the out side ones are at 1.75 turns but as soon as the 4wd is locked there is no play for the 2 inside tires. the diff is trying to take some play but it can not so it binds up and forces the tire to slip kind of trying to make it go in reverse as u go forward very bad for axles and difs
01 GRAND VITARA
Offline r3cc0s
  • 321
« Reply #5 on: March 01, 2005, 07:13:27 AM »
well silly me
well I figured that I would try climbing a couple parking blocks piled above each other, about 16" inches tall
well I just didn't have the juice in 2h to climb it, and it was a parking lot with a bit of snow/gravel
so I decided ah, 4lo ;)
nice to say I was able to idle climb it no problem
put my car in neutral and walk outside to admire the little articulation I had
walk out
and oh jeeze, my car launches at me about half a foot
as my back left tire spins a little
then aah.. I realized, I forgot 4 wheel drive on pavement
:P
