Shock Question?
  • 1769 Views
Offline Zuki One
  • 441
    • ZUKI - PICS
Shock Question?
« on: June 30, 2004, 04:42:25 PM »
Anybody run there front shocks upside down ive seen it done is ther an advantage ?The reason bieng is my shocks are hittin the ubolt plates?
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
Re: Shock Question?
« Reply #1 on: June 30, 2004, 07:15:26 PM »
Must be on a Sammie, ya go for it
better that wrecking your shocks
Re: Shock Question?
« Reply #2 on: July 01, 2004, 04:01:32 AM »
Will they work upside down? would that cause the oil to drain away from the valving? I know old bike shocks have to go up a certain way. Don't know about Zuk ones
Offline TomKat
  • 211
Re: Shock Question?
« Reply #3 on: July 01, 2004, 04:53:52 AM »
I know you can run Doetch tech's upside down, some others won't work properly due to the aforementioned oil for the valving. Check with the manufacturer. The oil issue is the only deciding factor.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline suzi_n_sammy
  • 184
  • Rock the Sam
Re: Shock Question?
« Reply #4 on: July 01, 2004, 12:21:41 PM »
i think ill hi jack this thread sorry zuk1 :-[
would it make any clearence difference to switch out the calmini shocks on my sammy with lets say the rancho shocks on spidertrax. If im not mistaken the shock body is longer so could you gain and inch or so with those ? just pondering.
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
