beginner questions on sidekick
  • 67 Replies
  • 19375 Views
0 Members and 19 Guests are viewing this topic.
spyder0069
Re: beginner questions on sidekick
« Reply #60 on: January 06, 2008, 08:58:48 AM »
Oh yeah.  And walmart sells a small car fire extinguisher that I found will pop into the glove compartment.  I didn't want to mount it out where the 15 year old vandals could get to it if the top was down.  :^)
Probably the only thing maintenance wise I have yet to do it attend to the brake rotors.  I can feel the pedal pumping when coming to a stop and I am sure they are warped.  Years back I had to replace them on a geo metro and the wheel bearing had to come out with it.  How about on these?
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #61 on: January 06, 2008, 01:27:54 PM »
On the kick they are independent from the hub.
Student of Now Master of Then
94tracker
« Reply #62 on: February 24, 2008, 12:29:29 PM »
About running cool in winter
I found out if you run stronger than 50-50 antifreeze the cooling system will overcool it. 50-50 works better.
spyder0069
« Reply #63 on: February 24, 2008, 06:52:02 PM »
The new 195 degree thermostat has really helped out the winter running.  I found another issue which was the driver door was letting in a considerable amount of draft at the back of the door.  The u shaped door latch on the body had moved and the door was no longer making a seal.  I losened the screws and tapped it in and retightened and it elminated more of the wind noise and cold air coming in right behind my head. :^)
Offline tracker8v4x4
  • 128
    • cardomain
« Reply #64 on: March 07, 2008, 04:57:49 PM »
30x9.5x15 fit no problem here is a pic of mine http://www.cardomain.com/ride/2934945
Offline Carnage
  • 2453
« Reply #65 on: March 07, 2008, 05:09:24 PM »
hmmm... i dont recall but did you answer my question about the short shifter?
  • 128
    • cardomain
« Reply #66 on: March 08, 2008, 05:11:09 PM »
yea i sent u a comment on cardomain
Offline Carnage
  • 2453
« Reply #67 on: March 08, 2008, 07:49:49 PM »
cool cool
