If ANYTHING is going to look like Jake's 4 Door...
  • 27 Replies
  • 3555 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
Re: If ANYTHING is going to look like Jake's 4 Doo
« Reply #15 on: November 06, 2004, 03:03:39 AM »
Except for the body, It's not a ZUK!
It's too high!
It's UGLY!!!!!!!!!!!!
I hate this truck!
Bigger is not always better...
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #16 on: November 06, 2004, 03:27:30 AM »
It's too high!
I hate this truck!
Fredo
hahahaha
You can't take something that's all Suzuki and make it that high. It's too bad.
I mean, I'm now going to be running Toy axles. At least I'll still have the zuk engine...
:P
;D
Heather Galvin
Offline Fredo
  • 416
« Reply #17 on: November 06, 2004, 07:10:47 AM »
Toyota is cool!
Not chevy, ford or other shit like that...
Fredo
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #18 on: November 07, 2004, 10:32:33 PM »
Heather, are yoiu gonna upsize tires as well? Just wondering what you are shooting for. I bet Mike Whitfield is watching your build very closely ;)
www.Zuwharrie.com[/url]
Offline Natebert
  • 1098
« Reply #19 on: November 08, 2004, 02:00:15 AM »
I don't think she's decided yet.
If we stick with 35's there is still a chance it will fit in the garage, and since its her daily driver I know that this is still a concern for her.  Scraping windows in the winter-time sucks.   Leaving expensive vehicles exposed to the elements sucks.  Thieves suck.
We think we can go to ~ 36's or 37's with the current suspension setup, without having to lift it any further.  But I'm pretty sure its garage days would be over then.
However, we are reloacting spring hangers and shackles to widen (4 inches) the springs and to push the tires forward and rearward further (an inch in each direction) for more stability, better aproach angles, etc.  So we may be able to go a bit larger tire afterwards.  It just depends on where the suspension ends up.  So I'd say that tire size question is still up in the air.
Fortunately, gearing isn't a question at this time.
It's all about stability and drivablity.
Our trip to Moab last year was great.  But if you were there, you'd a seen me out spotting her while going over nearly everything.  Even over stuff I wouldn't have even given a second thought about before the lift, I was outside checking things out.  (which slowed us down a TON, just ask the guys.  They had great patience for us.)
But we were learning about the new ride.  We difinately had some pucker factor due to the additional lift, especially since we didn't have any time to play with it after we lifted it before Moab.   But after 12 additional inches if height and no additional width.  The sidehill stuff still makes me wonder, how far we REALLY are from taking a ride over on its side.
All the following camping trips, to and from work, and driving around town proved that the existing setup was tolerable AND a bit top heavy at the same time.
Its stuck to the ground when it was supposed to be and it goes onto two wheels nearly on command when on the pavement if I ask it to.  (sharp corners)
I'm hoping with the additional width, sway bars, new springs/bushings that all of this will be taken care of.
So I don't whink we plan on taking it much higher to accomodate larger tires.
Just the largest we can go with the way it sits now.
~Nate
« Reply #20 on: November 08, 2004, 02:45:23 AM »
I've got a solution for you. 37 MTR's on Hummer wheels with the auto inflate/deflate  :o Then you could just air down 3-4 psi and pull in the garage ;D
Offline Natebert
  • 1098
« Reply #21 on: November 08, 2004, 05:10:46 AM »
THAT, would be just plain old crazy.
8)
I like it
Offline jagular7
  • 1026
  • Jagular7
« Reply #22 on: November 08, 2004, 05:34:06 AM »
Or is there space in the header of the garage for a little raise? Or room on the side of the garage for another (seem to recall something of a short driveway and lots of fense in your neighborhood from old pics)?
On a corner lot? Cool to have a garage on the end corner side and to have entry and exit doors on both sides of the garage, entrance from street, exit through back yard and fense - sort of a pass-through with large doors.
As you are going wider, isn't going to suck to constantly clean the side windows from the road spray off the tires? Mind you the rear view mirrors also?
Lenexa, KS
Offline explosivo
  • 3157
« Reply #23 on: November 08, 2004, 05:47:40 AM »
Just buy one of those tent-garage thingers that's big enough to fit the Tracker ;D
omghi2.us[/url]
Offline Memphis
  • 107
  • Need a Rig
« Reply #24 on: November 08, 2004, 06:47:25 AM »
Buy Hydraulics!!! That way you can have super clearance and when ya gotta go into the garage just lower it LOL. I don't know where your going to pack the meats but a little fender trimming here and there might do the trick LOL.
You could have a low/high rider Zuki!!! LMAO
If you couldn't clear an object you could jump over it if you had a running start HAHAHA!
« Last Edit: November 08, 2004, 06:47:58 AM by memphis »
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #25 on: November 09, 2004, 11:16:05 AM »
Quit steeling my ideias..   ;D  Just kidding.   I don't have a garge...   But Hummer tires  ::)
Natebert:
  But we were learning about the new ride.  We difinately had some pucker factor due to the additional lift, especially since we didn't have any time to play with it after we lifted it before Moab.   But after 12 additional inches if height and no additional width.  The sidehill stuff still makes me wonder, how far we REALLY are from taking a ride over on its side.   :) ;) :)
 :)  Mine was about the same at Zuwharrie (maiden voyage, new limits, Locked & 4:1 + much more TIPPY).  With mine not being an On road vehicle.  Zuwharrie and the Roads to Camp & store were the first time it had been out fo the yard.  The added height definatly made it more tippy.
I'm thinking bigger, This will help with breakover and ground clearance issues, but the extra height & quicker tip over may not be acceptable.
« Last Edit: November 09, 2004, 11:16:49 AM by whitfield »
Offline shoyrtt
  • 161
« Reply #26 on: November 10, 2004, 06:56:01 AM »
Any info on Jake's rig? Is he using the mogs from the Sami?
Offline explosivo
  • 3157
« Reply #27 on: November 10, 2004, 07:10:16 AM »
Yeah. He posted here a little while back and said that he sold the sammy but kept the mogs and boggers ;)
omghi2.us[/url]
