Sidekick drive line flange does this mate to the toyota axle flange?
  • 1553 Views
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
I've been told that this mates right up. Is this true?
Mean Green Wheeling Machine
Offline bashzuk
  • 784
Re: Sidekick drive line flange does this mate to the toyota axle flange?
« Reply #1 on: February 06, 2009, 08:28:00 PM »
No one knows if this is true
« Reply #2 on: February 06, 2009, 10:36:37 PM »
Supposedly.   I have also read that you need to modify the drive line as well, getting rid of the lip, so the only thing holding it in place is the bolts. Low Range Off-Road has adaptors for 25 dollars a piece at http://www.lowrangeoffroad.com/samyotaswap.htm and is probably the easiest.  Did you find a set of Toy axles?
Another article I found mentioned that the transfercase side flange of the post 85 Toyota front drive shafts will bolt up to the large flange Tracker transfer cases.  Haven't seen confirmation on that though.
Offline bashzuk
  • 784
« Reply #3 on: February 09, 2009, 03:55:31 PM »
Yeah I have a set laying around and I'm trying to figure out if I'm going to use them or not.
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #4 on: February 09, 2009, 09:01:26 PM »
If you mean Sidekick driveshaft to Toy axle then the answer is not really. It will fit into the aligning hole in the center but only 2 bolts will line up, this is on an early Toy axle and I think the later ones have a bigger bolt pattern.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
