TORA Axle Spy Photos
  • 11 Replies
  • 3465 Views
« on: November 25, 2004, 07:52:46 PM »
Just released photos of the long awaited
TORA Axles
Enjoy
Offline Gear
  • 112
    • Pics and my club website
Re: TORA Axle Spy Photos
« Reply #1 on: November 25, 2004, 09:00:58 PM »
very nice :)
Jeff
'03 Grand Vitara & '89 SWB Vitara
Blue bits, Locked bits, Missing bits
Offline Speedracer7c
  • 2210
« Reply #2 on: November 26, 2004, 01:04:53 AM »
HOLY CRAP!
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #3 on: November 26, 2004, 01:44:52 AM »
sweeeeeeeeeeeeet! i want some!
i take it they can't be used on a standard front diff housing. will i need a ?calmini? front diff? (anvil???)
just wish i could have them now, and if i did, it'd be so long 31"s, bring on the 35"s!
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: November 26, 2004, 02:51:14 AM »
MEE TOO ;D When will we be able to "TRY" them? I'll definitly purchase a set. Please keep us informed.
Kevin
  • 2210
« Reply #5 on: November 26, 2004, 02:52:02 AM »
Do you need the anvil to have these? if so.....THAT SUCKS!
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #6 on: November 26, 2004, 09:30:13 AM »
Are they really that much stronger or whats there claim to fame ??? they look pretty sweet :D
At Lakeview Motorsports, were wasting your time already!
« Reply #7 on: November 27, 2004, 04:57:05 PM »
I don't know if both of the sides of
these axles are flanged, but if they
are I'm sure Kerry has a solution
to fix it, if not, I have a solution,
either way, stay posted
Offline track_this
  • 332
« Reply #8 on: November 27, 2004, 05:01:01 PM »
hey wild when you build your custom setup will you use the outer cvs with a slip shaft in the middle?? if so i wonder if kerrys cv would be the ultimate way to go since thier size is alot greater which pprobably will equal more strength.
shane
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
« Reply #9 on: November 27, 2004, 05:05:40 PM »
Wrong kind of CV to use with
a slip spline shaft, you don't
need a CV cup for that.
One trail bonus is the ease of
swapping broken shafts, if you
need to, you can seperate the
sections and drop in the replacement
while on the truck, no friends required
 ;D
Offline track_this
  • 332
« Reply #10 on: November 27, 2004, 05:12:12 PM »
ok so what kind of cv will you use?? are you going to use a sammy DS for the slip shaft?
shane
rear lockright
31" kumho m/t's
« Reply #11 on: November 27, 2004, 05:17:20 PM »
The cheep way would be to use a
Sammy DS, but I think it's too big.
So a custom half shaft and a HD CV
might be in order, undecided at this time
