sidekick sport axles
  • 10 Replies
  • 2457 Views
Offline smife
  • 179
« on: February 12, 2010, 10:11:38 AM »
Does a 96 Sidekick Sport 4 spd. auto have 5.12's? Also Are the axles longer? What would need to be switched on a 95 tracker to put sport axles underneath? Are the transfers the same?
Offline TrakJD
  • 232
Re: sidekick sport axles
« Reply #1 on: February 12, 2010, 01:05:46 PM »
You basically have 4.62 gears.  And I have ran 96 and up rear axles, they are massive and holds up just fine.  Go with 5.12 you ll be happy.  Transfer case, you can buy the gear set from Trail Tough.
« Reply #2 on: February 12, 2010, 07:50:56 PM »
Your sport should have 5.12 gears.
The axles and axle assemblies should be the same as any other 89-98 trackick....so they should interchange.
The transfer cases are interchangable with any other 89-98 trackick transfer case.  Note, that 89-95 transfer cases have a 26 spline output shaft, while 96-98 transfer cases have a 16 spline output shaft.
« Reply #3 on: February 13, 2010, 11:07:32 AM »
I thought the axles on the Sports were wider.
« Reply #4 on: February 13, 2010, 06:38:35 PM »
To the best of my knowledge - they are.
Offline jawman
  • 406
  • 1234
« Reply #5 on: February 15, 2010, 07:31:20 PM »
I thought they were wider too.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #6 on: February 17, 2010, 02:37:03 AM »
Yes, they are wider.
Offline 95Gstman
  • 78
« Reply #7 on: February 19, 2010, 08:11:36 PM »
Has anyone used them on the front of the none sport models to get more cv travel?
« Reply #8 on: February 20, 2010, 09:28:10 AM »
I'm using a front long side axle from a Grand Vitara, it's about 1/4" longer than
stock housing on my 89' Kick
Offline smife
  • 179
« Reply #9 on: February 20, 2010, 10:18:14 AM »
What does this do Wild?
« Reply #10 on: February 20, 2010, 04:12:29 PM »
I just grabbed it so I have 26 splines in the front
instead of the 22 that it came with.
