37's & power steering
  • 1161 Views
Offline Sidetracker
  • 30
« on: June 02, 2007, 08:05:57 PM »
I've read that someone is running 37's with ifs.  Do they use the stock power steering pump and box from a sidekick?  If they are, then there must be something wrong with mine, because it has a hard time with 31's
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: 37's & power steering
« Reply #1 on: June 02, 2007, 08:27:14 PM »
Nobody said it was easy to turn. ;D I think you are referring to our group. We are running 35-39.5 inch tires on kick powersteering but we also have severly lighted rigs with the front stretched and motors moved rearward. They turn compareable to a normal rig on 32s
Mike
Offline Sidetracker
  • 30
« Reply #2 on: June 03, 2007, 05:51:39 AM »
Thanks Mike. Is there any upgrades that can be done to the stock system?
Dave
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #3 on: June 03, 2007, 09:00:29 AM »
Dave
Not that Im aware of. :-[
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #4 on: June 03, 2007, 10:18:39 AM »
I'm having the same problem with mine.  I have 32-11.50MTR's and there a bear to turn.  Others I've talked to don't have this problem with the same type of tires.
Some one once sugested to take apart the stearing pump and you can put a nickle or something like it behind the spring that reg. the pump pressure.
96 Tracker
32 MTR's Warn 8000i
« Reply #5 on: June 03, 2007, 10:32:04 AM »
Mines OK with 33 x 9.5s. A little firmer but it always seemed a bit too light stock anyway. Over here there are two types of pump, with a fixed pulley and with a removable pulley. Maybe theres a difference?
Offline fieroboy_gt
  • 59
  • whoo
« Reply #6 on: June 03, 2007, 11:55:45 AM »
I got 33 on my sammi no power steerin an there not a poblem to turn
Cars an Guitars an my band Insurrection
