skid marks
  • 40 Replies
  • 10211 Views
Offline RACER X
  • 383
  • zuki or die!
skid marks
« on: May 26, 2008, 03:51:59 PM »
Im thinling of making one big skid plate to cover from the a-arms to the rear dif
what do you guys think
98 kick
phloop
Re: skid marks
« Reply #1 on: May 26, 2008, 08:04:23 PM »
Why? A Sami doesn't have A arms.
Offline big_kountry21
  • 415
  • 1 bad mamajama
Re: skid marks
« Reply #2 on: May 26, 2008, 09:08:29 PM »
track kicks have a arms
camo 96' trak 16v 2dr 4x4
235/75/R15 MT's 15x8 black wagon wheels
5.13 gears 3" calmini body lift..
Offline olija
  • 770
    • Check out my cardomain
Re: skid marks
« Reply #3 on: May 26, 2008, 10:02:42 PM »
I think it's a great idea if you plan to scrape and bash the crap out of your vehicle. It's going to weigh A LOT if you do it out of steel though! I have fairly modest skidplates for my front diff, transmisson, and transfer case and all together they probably weigh about 80 pounds.
Re: skid marks
« Reply #4 on: May 26, 2008, 10:33:13 PM »
Yikes - what other material cold be used to keep the weight down, but still offer protection?
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: skid marks
« Reply #5 on: May 27, 2008, 11:25:08 AM »
Mike Hagon use to run a solid skid from the front to where the rear drive shaft comes out of the trany.  I forgot the gage of metal he used but it was very thin.  I think I have the spect's at home.
The only problem he said he had was that his feet got hot in the summer from the cat.
96 Tracker
32 MTR's Warn 8000i
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
Re: skid marks
« Reply #6 on: May 27, 2008, 11:52:47 AM »
My choice would be 1/4 inch thick plastic, like the kind white cutting boards are made of. It would require lg. washers tho, and maybe some bracketry to allow recessed or hidden fasteners. I bet it would slide like grease!
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
Offline bzzr2
  • 1011
Re: skid marks
« Reply #7 on: May 27, 2008, 12:53:06 PM »
lol, plastic..  serious?!  it's not a skateboard!
09 taco reg cab short box 4x4
Offline RACER X
  • 383
  • zuki or die!
Re: skid marks
« Reply #8 on: May 27, 2008, 05:59:55 PM »
1/4 inch aluminum or the plastic cutting board stuff is what i was thinking of using
98 kick
Offline Trackin_Tracker33
  • 137
  • Have Gun will travel
Re: skid marks
« Reply #9 on: May 27, 2008, 07:59:31 PM »
I'm getting ready to make my plastic skids in a week or so. Ill post pics....soon   I don't remember the name of the plastic, but its stronger than steel could ever be. My father Runs a trainyard in Indy and they use this plastic to line there 13ton train cars to haul steel.
I got your Jeep thang,  thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS,  SAS'N it
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
Re: skid marks
« Reply #10 on: May 27, 2008, 08:33:11 PM »
I think rally cars use teflon. I think the cutting board stuff is formica, I know they make sand boards for riding down dunes and being pulled my sand rails out of it.
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
Offline locjaw
  • 2045
  • 22
Re: skid marks
« Reply #11 on: May 27, 2008, 08:49:59 PM »
most of the "white plastic" stuff is U.H.M.W plastic which stands for "ultra high moclecular weight" plastic. good stuff. tough as nails, slicker than snot! it is used a lot in the machenery industry(wood products, food procesing, ect...) can be ordered thru most steel yards. you will want to use like 1/2 inch thick just for it's sheer strength and so you have depth to recess fasteners.
Offline RACER X
  • 383
  • zuki or die!
Re: skid marks
« Reply #12 on: May 27, 2008, 08:51:18 PM »
plastic im talking about 1/4 thick sold in 8'x10' sheet at the countertop place by my work runs 100 a sheet
98 kick
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
Re: skid marks
« Reply #13 on: May 27, 2008, 11:58:52 PM »
 I recently saw a rig that used 12 ga steel for the skid plates to save weight,and then had plastic over it.It supposedly took a beating and the plastic slid great.
KING ZOO!!
Offline bzzr2
  • 1011
Re: skid marks
« Reply #14 on: May 29, 2008, 06:13:26 AM »
hhhmmm, i'd like to see this, for now i retract my skateboard statement - good luck!
