Sky idler arm?
  • 17 Replies
  • 3942 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
Sky idler arm?
« on: November 06, 2007, 06:19:33 PM »
Who's got one of these and what do you think about it?  Worth the $100 or so?
My stock idler arm is loose and starting to affect it's ability to hold an alignment so I think I'd better start looking for a replacement...and if I'm replacing it why not upgrade?
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: Sky idler arm?
« Reply #1 on: November 06, 2007, 06:29:41 PM »
I couldnt say enough good things about the sky idler.  Eight people in our offroad club are runnin them and I can assure you they are completely indestructable.  8)
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Sky idler arm?
« Reply #2 on: November 06, 2007, 06:30:59 PM »
Schweet.  If Mike endorses it as indestructible you know it is.
Just because I've now been looking without success...where does one find a stock replacement idler arm...none of the online parts houses even list it?
Offline olija
  • 770
    • Check out my cardomain
Re: Sky idler arm?
« Reply #3 on: November 06, 2007, 09:10:55 PM »
Try the junkyard.
My issue with installing something that beefy in the steering system is this: It removes the weak point from the system...which means that next time you hit that same rock too hard, it's could be something else that costs more to replace.
Offline satan inside
  • 68
  • bodylifts are for rednecks
Re: Sky idler arm?
« Reply #4 on: November 06, 2007, 10:13:37 PM »
I have one. its very well made.
my friend said "thats a pretty bling piece to be putting in a suzuki"  >:D
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Sky idler arm?
« Reply #5 on: November 06, 2007, 10:16:43 PM »
I removed all the steering linkages from a wrecked sidekick in a u-pull-it yard, and i kept the idler arm attached.  That's all the tie rod ends, and everything in between.  I'm keeping it for that rainy day if i ever have a problem with any of my parts.
BTW, they only charge $1 per foot of tie rods/drag links, etc at that junkyard, so it was a very good deal.
1993 4-door Sidekick
4.24:1 t-case
Re: Sky idler arm?
« Reply #6 on: November 07, 2007, 03:39:43 AM »
Bent the stock one ( bentparts!) replaced it with the Sky's, and made up a lower brace. Indestructable and very well made.
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Sky idler arm?
« Reply #7 on: November 07, 2007, 04:20:47 AM »
For what I do in 4x4...mainly get to work in the winter...it'll be overkill...
...but then the junkyards up here won't sell you the steering wheel horn cover for a buck around here...and I've seen all the Sidekicks/Trackers they have around here...
Sky it is. 8)
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Sky idler arm?
« Reply #8 on: November 07, 2007, 07:55:19 AM »
Mine works great! I think there on backorder though ???
     Kevin
Offline Uncivilized
  • 1469
    • Car Domain
Re: Sky idler arm?
« Reply #9 on: November 07, 2007, 12:32:53 PM »
That's what you think! I bent a stock one before sliding into a curb in a snow covered parking lot.
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Sky idler arm?
« Reply #10 on: November 07, 2007, 03:53:44 PM »
Better to have too much than not enough.
Not to mention at 170,000 miles or so it's hard to say mine hasn't lived a long life...
Re: Sky idler arm?
« Reply #11 on: November 08, 2007, 07:02:19 AM »
DON"T FORGET THE BUSHING!
It's replaceable, cost under $10 for the Moog part, and makes a world of difference if you have wiggle in the idle arm.
but if you are going large tires, then upgrade to Sky arm AND add the Calmini arm brace.
Offline crikeymike
  • 713
Re: Sky idler arm?
« Reply #12 on: November 08, 2007, 02:18:28 PM »
Thanks, I didn't know that, and probably wouldn't have thought to replace the bushing first.
4.24:1 t-case
Re: Sky idler arm?
« Reply #13 on: November 09, 2007, 07:40:06 AM »
I changed the one on Wifey's, and all the slop in it went away.  Rock Auto has them for $8.
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Sky idler arm?
« Reply #14 on: November 09, 2007, 08:06:08 AM »
What's the procedure for changing the bushing?
