using a stock samurai tie rod on the toyota swap?
  • 2548 Views
Offline zuki guy
« on: April 13, 2008, 03:05:26 PM »
just wandering if i could use the stock samurai tie rod with a toyota axle swap. I have been wheeling for years upgraded my tires to 33 tsl boggers started breaking axles so decided on the swap. Also wanderng if anyone might have a rat adapter 4-sale?
Offline Amilla
  • 1076
Re: using a stock samurai tie rod on the toyota swap?
« Reply #1 on: April 14, 2008, 11:43:33 AM »
Dont think so, the sami tie rod is quite a bit shorter.  300 bucks and you get full high steer for a yota, tie rod, drag link, 4 FJ 80 rod ends, and some bling billet steering arms!
Amilla
« Reply #2 on: April 14, 2008, 12:16:16 PM »
An  alternative might be to try out the new chromoly axle shafts.  They should be able to hold up to the larger tires.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #3 on: April 14, 2008, 01:44:42 PM »
the tie rod IS interchangable I use mine every day with 35" tires, you do however have to cut, sleeve and lenthen your shaft, I run a sami drag link to a flipped yota arm for a stage one high steer,  works great, and I have 2 rat adapters but I need to trade my yota axles for a set of full width 44's 6 lug pass side drop and center rear! hint hint
