Locker ?'s
  • 1341 Views
Offline suzi_n_sammy
  • 184
  • Rock the Sam
Locker ?'s
« on: September 11, 2004, 12:51:52 PM »
alrighty,
i got a couple questions. I have 6.5:1 t-case gears and in 2 days im going to be able to afford 33's. so do i need to change the ring and pinion? if so will i be able to re use the lock right lockers? and if i need to replace what ratio should i get? I know it a lot of questions, thanks mucho.
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
Offline overkill
  • 14
  • I love YaBB 1G - SP1!
    • www.overkill4x4.com
Re: Locker ?'s
« Reply #1 on: September 11, 2004, 01:04:29 PM »
I would say the gearing would be okay to run 33s. I used to run 6.12 and 33 with standard diffs and was okay. I stupidly went to 4.16 and had to change the diffs to 4.65 to get the same on rode drivability.
Another option to lockers is traction controll. ;) ;)
Offline cj
  • 1276
  • I drive a really big ATV
Re: Locker ?'s
« Reply #2 on: September 11, 2004, 03:16:03 PM »
I was wondering when this would get a mention as it would solve the locker problem for the XL-7's. Maybe start a new thread to tell a liitle more about this.
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: Locker ?'s
« Reply #3 on: September 11, 2004, 11:18:44 PM »
Well the 6.5:1 gears (if they are Trail Tough gears) offer a 17% gear reduction in high gear. This isn't quite enough to get enough gearing for your 33's. So that being said I would reccoment getting a set of 4.62's or 4.889's and put them in. Yes you can reuse your old lockers so that is a bonus. Best of luck!
www.Zuwharrie.com[/url]
