Solid axle sidekick
  • 28 Replies
  • 12553 Views
Solid axle sidekick
« on: June 16, 2009, 11:51:56 PM »
I am not sure if there is already a thread about this, but I am planning on doing a solid axle swap on a '89 sidekick. I want to use a Dana 30 (Jeep front axle) as they have the same bolt pattern as the kick, but I may be doing a Dana 35 in the rear at the same time or maybe later on. The plan is to have a rig for general off- road, I dont particularly do rock crawling but that seems like a good type of vehicle to aim for. I just want to be able to go anywhere, including on-road.
So, what I am wondering is, should I go with leaf springs or coil springs?
The kick is currently running coils, which I hear gives a softer ride with more articulation. If I do coils then I would have to design a whole four-link system and buy expensive heim joints and stuff. I could also do a radius arm setup like coilspring jeeps have (cherokees are the only ones I know of).
Leaf springs would be more simple and some people prefer for this and the fact that they are easy(-er than coils with 4-link/radius arms) to install. But I hear that they are generally stiffer and have less articulation. But couldn't this be fixed with longer and softer springs?
Most of the articles I have seen that compare coils and leaves end up with saying that coils are technically better but leaves are just fine. I have all the materials I would need and I have fabrication skills (which would mean the more complicated coil spring set up is a little less complicated than for most people), but this project is supposed to be a budget weekend warrior. So, should I go with the easy, simple, and cheaper leaf spring set up or should I do the more complicated, more expensive, coil spring set up?
Any info on the leaf/coil comparison is appreciated. I just cant decide if coils are worth the extra time and money.
Re: Solid axle sidekick
« Reply #1 on: June 17, 2009, 09:16:19 AM »
Anything can be made to work.  A Leaf Spring setup is going to be easier, but if you have the time to plan it out a 4 link setup isn't that hard.  You can make it even easier by building a 3 link setup instead of a 4 link so you don't need to worry quite as much about your triangulation.
And you don't need to use Heims, you can just use the ends you already have.  For half of my suspension I actually cut the eye's off of a set of leaf springs and welded them onto the arms, that way if I need to replace the bushings I can just order a stock set of replacements.
As for the rear axle, I would go with an 8.8 or something besides the Dana 35c.  Just to avoid getting stuck with a c-clip style rear end.  If your swapping both axles you might as well look at changing the bolt pattern at the same time unless you have a really fancy set of wheels.   Your front axle is going to have to be from a CJ series, on the YJ and Cherokees they switched over to 5 on 4.5 bolt pattern.
Are you building this for trail only or for road and trail use?
« Reply #2 on: June 17, 2009, 10:08:36 AM »
I am still loving the Trail Slayer link set up Liberty Overland did on mine. Even with the 37's my Kick sees more pavement than trail action and does awesome in both situations. I'm hoping to do a 6 hour drive to Attica (iZook's ZukiMelt) next weekend, trail ride and drive her home. But in the opposite spectrum, a friend of mine did his SAS Tundra with leafs and he always drives to events with me too (he did last years Ultimate Adventure and is doing it again this year). The main issue he had to tackle was axle wrap and trashing his springs.
  • 6589
« Reply #3 on: June 17, 2009, 10:17:24 AM »
It sounds like your pretty sold on leafs but I can say without a doubt... go with the coils and a good link setup. There are so many aspects of ride and performance that are better with coils in almost every instance that make the extra work worth it. PLUS: The Sidekick already has coil buckets on the frame, good placement for shocks on the frame, and comes with a pair of links (bottom rear) that can be sleeved and will make great long travel links if you're on a budget. Just go to the local wrecker and get 3 or 4 sets of these stock links and some good tubing and boom! you're 1/3 the way there! :)
Or, by a kit to do it. It is worth it....
Also, consider Toyota or Dana 44 axles.. The ones you've suggested just won't perform without big upgrades or big breakage.
YMMV
Good luck, Eric
« Reply #4 on: June 17, 2009, 08:12:23 PM »
Great, thanks for the info guys. To answer a few of your questions: yes I will be driving it on the road, probably about as much as on the trail. Actually the way Zukipilot described his rig sounds like exactly what I want. I forgot to mention that I want to run at least 35" tires.
I may have made it sound like I'm leaning towards the leaves, but I was actually thinking coils would be better, but a part of me just wants to do what is easier, haha.
Well it sounds like you guys are pretty much against my Dana 30 idea. I just found a guy with just a 30 for $250 or the 30 and 35 for $400. I was just trying to decide if that was a good deal (I dont really know what they are worth). They have 3.07 gears and the rear is welded. I figured with a little 1.6 liter engine I wouldnt need to worry about the strength too much, but I probably would need lower gears. Is this really a problem? Again, this is a budget build, I want the cheapest thing that will work.
« Reply #5 on: June 17, 2009, 10:52:43 PM »
Zukipilot, do you have a build thread or something for your car? I would love to see all of the detail shots of the suspension set up and everything. It would be really nice to have something to model my suspension after when I do the SAS. Thanks.
« Reply #6 on: June 18, 2009, 06:23:41 AM »
http://zukiworld.com/month_020109/feature_suzuki-sidekick-build-up.htm  ;) There is a link to Liberty Overland's web page in the article that will give you a few more pics.
If you go with the C-clip Jeep axles I don't think they have very low gearing. For example, our stock gearing for a 5 sped is a 5.18 (I think) and if you get a 4:1 t-case reduction turning 35's you will start to have axle breakage. I have Toyota axles in mine with longfield upgrades. They have been doing great holding up to the 37's.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #7 on: June 19, 2009, 05:45:11 PM »
We recently did the sleeve thing on lower links.  Here is what we did. pounded a piece of tube through the frame in the factory frame holes one forward of the stock link location. Purchased these cool brackets from ballistic fab and a triangle gusset from IMS. Little welding, little griding, little pounding and wabam! lower link mount that is tough and on the frame. For the link we cut and sleeved the factory links.
Offline Armour
  • 360
« Reply #8 on: June 19, 2009, 06:01:33 PM »
I have run this set up on mine for the past couple of years! Works great!
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #9 on: June 20, 2009, 07:54:39 AM »
Thats cool, I really like that idea. Do you have any pictures of how you mounted the upper link/links?
Student of Now Master of Then
Offline cmays03
  • 99
« Reply #10 on: June 20, 2009, 05:16:40 PM »
I think I'm going to take my 6.5 lift off my jeep cherokee and make it work under my 95 tracker. going to 4 link it all with the coils from the front of the jeep and find two more coils for the back. I think it will look awesome when its done. I will take notes and pictures when i do mine. I'll be running 33" tires for now but will see about 35 or bigger down the road.
95 geo tracker sas with dana 30,35 axles 3.55 gears, 33 tsl's, 3 and 4 link suspension. stock motor trans, tcase has 4.24:1 reduction kit.
Offline ToyYoda
  • 226
« Reply #11 on: June 21, 2009, 10:04:55 AM »
I weighed out the "cost vs gain" on my Suzuki & for me a Trail Tough kit was hard to beat. You would be well advised to make a call to Liberty Overland as they know well both side of the mod. your thinking of. I can tell you that a short wheel base veh. with altered lift can have a VERY poor ride on freeways & most other roads. Coil suspended veh.s ride better plus it's abillity to articulate is far better with the coil/link kits.
« Reply #12 on: June 21, 2009, 11:26:46 PM »
I am still a little new to the world of 4x4s, so I don't know a much about gearing and stuff. Zukipilot, you said Toyota axles would be better because the Danas have high gearing (by the way, you mentioned stock kick gearing for a 5 spd kick, but mine is automatc. Does that make a difference?) and will break with large tires (35" minimum). Is that only after you replace the stock birfields with longfields and change the gearing? Could I put stock axles (danas or yotas) on the car and just expect to break either axles or ring and pinion? Because either way I would end up replacing them right? It will be alot easier to spend money gradually than all at once. I have many hobbies and all of them require money so unfortunately even the little bit that I make cannot all go to the kick.
I was at the junkyard the other day and saw a newer model jeep grand Cherokee with what looked like good axles, it was a 1997 I believe. I'm not sure if I should even be considering a D30 and D35 anymore after the feedback I have gotten from you guys, but I think I could get these axles for a decent price so it is tempting. The only thing is that the front axle had CV joints instead of u-joints. I'm guessing CVs would not be
recommended?
Thanks guys, so far this thread has been very helpful.
« Last Edit: June 21, 2009, 11:54:05 PM by chestertalley »
« Reply #13 on: June 22, 2009, 05:17:47 AM »
Yea, you can fix as you go. The down fall to the C-clip style axles is when you break them. There is nothing holding your axle in place but the C-clip that is located in the center section. So broken axle usually results in wheel falling off, broken brake lines etc....
There are some guys here that are running up to 39's on a Toyota CV conversion kit that user '37kicker' sells. If you are wanting to stay IFS, that kit would fix your CV weak point, but you would probably want to go with a steel housing too.
Good luck on your build, keep us updated...
« Reply #14 on: June 22, 2009, 01:39:45 PM »
Coils are far & above superior. I have a good amount of experience with both. I've never setup either, but I've done a lot of keyboard engineering (will be doing my first suspension soon), and coils don't look like they're that much more difficult to setup. Just a little more thought needs to go into it, and what you get is a better-riding vehicle, and no axle wrap. If you get a little sag from more weight down the road (adding armor, winch or whatever) a coil spring spacer is easy to install and re-level the rig.
