Spare tire mounting options for 4-door kick
  • 22 Replies
  • 5466 Views
0 Members and 24 Guests are viewing this topic.
Offline robozuki
  • 33
« on: August 22, 2005, 05:22:33 PM »
Since there doesn't seem to be any swing-out tire carrier bumpers for the 4-door sidekick, I was wondering if any of you 4-door owners came up with any mounting points for your spare tire?  Obviously roof rack or inside behind the rear seats would be the 2 easy places.  Has anyone tried to mount it on the back door using a bracket that lifts it high enough to clear the bumper?  Canthe back door take the weight of a 31" or 33"?
Re: Spare tire mounting options for 4-door kick
« Reply #1 on: August 22, 2005, 09:46:53 PM »
Well, From what I know and will be doing later is to modify the stock carrier to fit.
"say what " you say?
THis is what a friend did to his.
He cut off just the part that holds the wheel.
Placed it on his bigger wheel.
Set the spare tire on the bumper and rewelded it back together.
This way some of the wieght is resting on the bumper.
(his is a 2dr covertable)
He also said he hasn't had a problem with it.
BTW. Make sure the rubber tire stops (on the door)are tight against the tire so it doesn't wobble and bend the tailgate.
They may need to be cut shorter tho.
« Reply #2 on: August 22, 2005, 09:53:48 PM »
Kind've like so
Hope this helps alittle
Offline robozuki
  • 33
« Reply #3 on: August 23, 2005, 12:09:35 AM »
ahhh. Yes, much simpler than a custom bumper.  A jeep-driving friend of mine said I should just put wheel spacers on there so that it clears (and hangs behind) the bumper.  Ridiculous.
Modifying the mount though...seems simple enough.  I may decide to go with the cheaper tube bumper then, and keep it mounted to the door.
Perhaps I shoule add some kind of plate on the inside of the door as a brace...
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #4 on: August 23, 2005, 03:58:42 AM »
Friend don't let friends drive Jeeps.  ;D
Offline echojeff
  • 414
  • Lo que sea
« Reply #5 on: August 23, 2005, 05:34:17 AM »
Here is a link to a home made swingaway bumper/hitch/spare tire ect that Heather's 4dr has.
http://www.granitepath.com/~kd7hcg/pictures/rearbumper/index.htm
95 Kick 4dr JLX.
« Reply #6 on: August 23, 2005, 07:38:14 AM »
Look at this.  It fits a 5 on 5 1/2 lug pattern so it will bolt right on a sidekick.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7993915415&sspagename=STRK%3AMESE%3AIT
here is an Izook review
http://izook.com/reviews/dossparetire/dossparetire.htm
Somewhere just south of sober in a hazy little town.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #7 on: August 23, 2005, 09:23:45 AM »
FYI:  I had a 31 on my back gate, when I had no bumper.  The weight of the tire BROKE THE WELD on the stock tire carrier.  I would not recommend any solution that includes the stock tire carrier.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #8 on: August 23, 2005, 11:55:58 AM »
+1
Also, when we hard a 31 on our tire carrier, it weakened the hinges on the back door.
Heather Galvin
« Reply #9 on: August 23, 2005, 12:04:36 PM »
I have been running my 33 on the stock mount for years with no trouble. I think mine has held up good because my 33x12.50 and a 15x10 rim with 4" BS pulls the rubber tight against the door keeping it moving at all when tightned down.
Were your 31's spaced away from the door or pulled tight agains it?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #10 on: August 23, 2005, 02:14:21 PM »
As I recall it wasn't tight against the door.  Once the weld broke, it DEFINITELY wasn't tight against the door.
Bob
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #11 on: August 23, 2005, 10:31:17 PM »
here's what i did to mine. i drilled out the spot welds and moved the carrier up 1" and bolted it back together and welded the crap out of it. i welded angle iron onto the tire mounting part to strengthen it and added the small piece at the top. so far so good.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Deathrunner
  • 33
  • Don't have a zuk, but a man can dream...right?
« Reply #12 on: November 17, 2005, 03:47:46 PM »
That's cool if you don't want to swing your door open. LOL
T.O.Y.O.T.A.
Take Off Yer Oversized Tires A$$hole
Offline SnoFalls
  • 1358
« Reply #13 on: November 17, 2005, 07:05:25 PM »
x2 ... no way that mount has any business carrying anything more than a 27" tire.
Offline derekj
  • 784
« Reply #14 on: November 17, 2005, 10:34:22 PM »
my tire is on the roof now. after welding the crap out of it now the door creaks. i'm thinking of mounting it inside the vehicle because the plastic hard top doesn't seem to like the weight.
derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
