Spare tire mounting options for 4-door kick
  • 22 Replies
  • 5456 Views
0 Members and 21 Guests are viewing this topic.
Offline Uncivilized
  • 1469
    • Car Domain
Re: Spare tire mounting options for 4-door kick
« Reply #15 on: November 17, 2005, 10:44:25 PM »
That's a lot of weight to put on thoes tops... About 60lbs of wheel/tire I think, it could cause cracking in the fiberglass.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #16 on: November 18, 2005, 03:39:02 PM »
I've run both a 30" and a 31" tire on the back gate and never had a problem before.  My 30" fit fine one i had the body lift on.
1993 4-door Sidekick
4.24:1 t-case
Offline SnoFalls
  • 1358
« Reply #17 on: November 18, 2005, 03:52:49 PM »
yea but mike ... but, for how long ... once we leave the easy stuff, it'll really be floggin around back there.
Offline crikeymike
  • 713
« Reply #18 on: November 18, 2005, 04:24:13 PM »
i don't think you've got much experience with it since you don't even carry a spare.
3 years was the longest with a 30" on my 2-door.  Lots of dune driving and jumping, down in Oz, and it was an 89 model.  It never gave any indication of problems with both the mount or the hinges.
4.24:1 t-case
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« Reply #19 on: November 18, 2005, 04:33:17 PM »
Here is my mod to fit the 30" tyre.
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #20 on: November 19, 2005, 10:57:46 AM »
ahhh. Yes, much simpler than a custom bumper.  A jeep-driving friend of mine said I should just put wheel spacers on there so that it clears (and hangs behind) the bumper.  Ridiculous.
Modifying the mount though...seems simple enough.  I may decide to go with the cheaper tube bumper then, and keep it mounted to the door.
Perhaps I shoule add some kind of plate on the inside of the door as a brace...
a company called Designs of Steel sells a spare tire extension mounting bracket.  Check it out here: http://www.designsofsteel.com/SpareTireExtensionMount.htm
Ack
mudfkr
« Reply #21 on: November 19, 2005, 11:31:52 AM »
I cut my bracket and moved it up using 1"x1" box section. It handles the 30" I had on it OK but the 32" with a bigger back spaced rim has been giving the back door hell. I'm no longer going to have it on the back door and are still thinking of where to put ?
Left side you need to cut the bracket away at the top so the wiper can still work properly.
Offline Gear
  • 112
    • Pics and my club website
« Reply #22 on: November 19, 2005, 06:35:13 PM »
this is what i've done........
Jeff
'03 Grand Vitara & '89 SWB Vitara
Blue bits, Locked bits, Missing bits
