3" body lift
  • 1 Replies
  • 918 Views
Offline gpond
3" body lift
« on: November 11, 2008, 05:02:34 AM »
i would like to add a 3" lift. How do i get the mounts off. There are no nuts on the inside of the truck under the carpet? And can i take the whole body right off
Offline Uncivilized
  • 1469
    • Car Domain
Re: 3" body lift
« Reply #1 on: November 11, 2008, 08:41:21 AM »
If you're working on a Tracker/Sidekick:
They are studs welded the the body(except the two in the front) not bolts
You need to remove the nuts from underneath and lift the body.
See here for a great homemade body lift article:
http://www.zuwharrie.com/content/view/11/27/
Calmini 3" body lift install(similar to homemade really)
http://www.zukiworld.com/month_100101/feature_spyderman.htm
« Last Edit: November 11, 2008, 08:44:25 AM by Uncivilized »
