33's on a Sidekick with stock suspension?
  • 30 Replies
  • 4026 Views
Offline Maroon Monsoon
  • 876
Re: 33's on a Sidekick with stock suspension?
« Reply #30 on: May 19, 2006, 02:21:37 PM »
I know that on my GV that rubs stock tires in the back and front if it's thrashed enough that bottom out pad extenders will make bigger shocks work great once I lift it and probably make bigger tires bit just fine too.
Are the shock mounts on a GV not mounted to the frame like the earlier models?
the shock mounts are identical to the 1st gen ones I think. welded right on the frame.
here's a pic of the front and back suspension I took a while ago
