squeeking when turning....
  • 11 Replies
  • 2644 Views
0 Members and 20 Guests are viewing this topic.
Offline ddevil
  • 155
« on: August 26, 2006, 05:11:20 AM »
about a week ago i developed a pretty loud and really annoying squeek when i turn left or right.  and even sometimes after i turn and i'm driving straight it'll start then stop and start again etc...  it's coming from the front end, and sounds like either right under the front or from both wheels...  is it time for new cv's?
mike
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline nascarmanic
  • 31
Re: squeeking when turning....
« Reply #1 on: August 26, 2006, 06:54:10 AM »
Mike Do you have power steering? If you do check belt and or fluid level. CV's as a rule don't squeak. more like a grinding noise.
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #2 on: August 26, 2006, 07:14:30 AM »
check lower ball joints in the lower arms. the rubber boots could be split open, and the joint filling with crud, or drying out.
Offline ddevil
  • 155
« Reply #3 on: August 26, 2006, 07:32:57 AM »
yup i do have p/s... i didn't even give that a thought.  that would explain why the noise seems to be consistant with me turning the steering wheel.  i can be going down the road and slightly turn the wheel left and right(kinda make like swerving only really slightly) and i can get the squeek to well squeek... :P
i will check my balljoints just to be safe while i'm at it but i had the wheels and everything off a few weeks ago and checked everything out while i was working and the cv's and everything else seemed fine...
thanks guys,
mike
Offline nascarmanic
  • 31
« Reply #4 on: August 26, 2006, 07:41:25 AM »
Let us know if that was it.
Glad to be of help.
Frank
Offline ddevil
  • 155
« Reply #5 on: August 26, 2006, 09:26:11 AM »
well the p/s fluid level is normal, belts are in spec,  and the balljoint's look to be in decent shape.  i realised that the noise isn't from the p/s anyway because in order for the noise to be present i have to actually be moving some not the typical p/s belt screech noise.  it makes me think that it's something with the cv joints or the wheel bearings even because it has to be a part that rotates with the wheel,  unless perhaps it's just some loose gravel stuck in my brakes or something... hmmm....
mike
« Reply #6 on: August 26, 2006, 10:02:14 AM »
Wheel bearings rumble, CVs tick and clunk,
power steering squeals, to me all of these
noises are different, a squeek is like a body
mount shifting or an old vehicle when metal
pannels rub together
Offline nascarmanic
  • 31
« Reply #7 on: August 27, 2006, 05:29:10 AM »
Your front breaks might be down to the warning tabs.
Offline ddevil
  • 155
« Reply #8 on: August 27, 2006, 12:33:50 PM »
i think that's exactly what it is because when i go to stop the past couple days it starts squeekig.
mike
Offline nascarmanic
  • 31
« Reply #9 on: August 27, 2006, 01:35:07 PM »
COOL!!!!  THAT WAS EASY.
BEST OF LUCK
FRANK
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #10 on: August 28, 2006, 10:58:38 AM »
i had that noise to, since am cheap i just took the shoes off, cut the warning tab think put it back in and no more noise ;D
Offline nascarmanic
  • 31
« Reply #11 on: August 29, 2006, 09:08:42 AM »
UMMMM Lets see $12.00 pads or $12.00 pads and new rotors. Might add a little fender damage too if you don't stop in time.
Like they say "YOU CAN PAY ME NOW OR YOU CAN PAY ME LATER"
