Diesel adapter for 99+?
  • 1815 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: April 19, 2012, 06:33:06 PM »
I found lots of kits for the up to 98 era trackers and sidekicks, anybody know of adapters for the 99+ trackers?
Re: Diesel adapter for 99+?
« Reply #1 on: April 20, 2012, 06:01:17 AM »
Which one of the '99+ Trackers are you looking at ?
Trackers were available with 1.6, 2.0 & 2.5 litre engines - the 99+ 1.6 engine has the same bellhousing bolt pattern as the pre-99 1.6 engines and the same adapter should work, if I'm not mistaken, the 2.0 also uses the same bolt pattern, and the adapter should work there also.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: April 20, 2012, 12:04:51 PM »
I saw a really nice 04 xl7 with the 2.7v6, 5 spd.  I would even entertain the idea of swapping in a 98 transmission if that would work
« Reply #3 on: April 27, 2012, 03:00:51 PM »
Diesel models were widely available outside the US, maybe you could import a half-cut like someone else on here did for the early model.
