starting issue
  • 1097 Views
starting issue
« on: September 25, 2011, 11:34:44 PM »
I have a 86 sammi and sometimes when i go to start it i get power but no cranking over of any kind, ill release the clutch then push it in again with what seems like more force and it will start right up. is there a sensor or something that could be going out or maybe a starter issue? need some direction
Re: starting issue
« Reply #1 on: September 26, 2011, 05:52:38 AM »
Check above the clutch pedal see if you see a switch - some US models have a "clutch safety" switch that requires the clutch to be depressed before the starter will energize.
Offline talonxracer
  • 1284
Re: starting issue
« Reply #2 on: September 26, 2011, 06:31:13 AM »
That certainly sounds like the clutch pedal interlock switch needs to be adjusted.
