31x9.50 tsl's
  • 1597 Views
Offline smife
  • 179
31x9.50 tsl's
« on: February 10, 2010, 01:04:06 PM »
Are 31x9.5 tsl's too much for an auto tracker too turn over in the mud?
Re: 31x9.50 tsl's
« Reply #1 on: February 10, 2010, 01:17:37 PM »
No, but they may not spin them quickly.  What year Tracker do you have?  Depending on the gears you might be able to pick up some 5.12 ring and pinions from a manual and use them to drop your ratio a bit.
Offline smife
  • 179
Re: 31x9.50 tsl's
« Reply #2 on: February 10, 2010, 01:22:22 PM »
I have a 95 and I am planning on installing some 5.12's. I just don't want to lose too much power
Re: 31x9.50 tsl's
« Reply #3 on: February 10, 2010, 02:07:52 PM »
I have a 95 as well. Put in the 5.13's, you'll love it!  Perfect for 31, 32 even 33"s.
Offline bzzr2
  • 1011
Re: 31x9.50 tsl's
« Reply #4 on: February 12, 2010, 11:49:10 AM »
some more food for thought on those tires...  i ran them for 3yrs, loved them, not the best on rocks cause the tread is only 7.2 wide i believe but the point is they are lighter than your wider 31's, so this reduces your overall rotational mass.  for ex when i had these the weight was 47lbs per tire, my new tires are an inch taller and weigh in at 57lbs each, the difference in power is notable.
09 taco reg cab short box 4x4
