Steel front axle housing for suzuki sidekick
  • 17 Replies
  • 11004 Views
Re: Steel front axle housing for suzuki sidekick
« Reply #15 on: August 07, 2019, 07:07:31 PM »
I picked up one in Phoenix yesterday. He had at least one more.
« Reply #16 on: August 08, 2019, 03:30:00 PM »
Does anyone have any more information on making your own steel front differential? Could you offset it to work like the calmini anvil? 2 of the same length axles?
The link below will take you to Brd Hntr's build thread - the axle conversion is on page 2 of the thread, but it's probably a good idea to go through the whole thread - there's a lot of good stuff in there.
https://www.zukiworld.com/forum/build-diaries-how-to-diy/tracker-2x4-rockers-frnt-bmper-4-dr-sprngs-lwered-frnt-diff-$30-steel-frnt-diff/msg185688/#msg185688
« Reply #17 on: August 26, 2019, 01:33:10 PM »
On your question about offset, I think your talking about being able to use drivers side CV on both side.  For that you need to have someone build you an adapter, or just order one.  No change is needed on the width of the axle.  The only issue is making sure you get one for the right spline count.
Then you just need to bring a single spare CV for both sides and you can swap them out without pulling apart the side of your rig.
