Steel front axle housing for suzuki sidekick
  • 17 Replies
  • 10561 Views
« on: January 25, 2016, 02:51:23 PM »
Please excuse my ignorance, i have not been able to find the thread that will help me sort this out.  I am in much need of a steel axle housing for my sidekick.  I have broke two aluminum ones at this point and don't want to break another.  I have been searching craigslist high and low in order to find a xl7 or grand vitara with a steel housing.  do both the grand vitara and the xl7 steel axle housing bolt into place on my sidekick?
Thanks,
Dennis
Offline kreator
  • 634
  • 15
Re: Steel front axle housing for suzuki sidekick
« Reply #1 on: January 26, 2016, 03:26:41 PM »
My steel housings came out of a 1999 Grand Vitara with a manual trans and it bolt rite in with the Sidekick IFS brackets , you will need to make sure you put the correct gears in and take out the GV carrier . I dont know what XL7 has steel housings but I have heard that take differant IFS brackets.
  • 6571
  • 66
« Reply #2 on: February 03, 2016, 05:20:26 AM »
If you go to our home / main page and type in what you're searching for in the upper right hand corner.. you'll get some amazing results! :)
http://www2.zukiworld.com/?s=steel+sidekick
Good luck, Eric
« Reply #3 on: February 06, 2016, 09:09:59 AM »
Thank you gents.
« Reply #4 on: March 14, 2016, 01:55:38 PM »
I can confirm that the XL7 steel housing has different mounting brackets.  I learned the hard way after finding one and buying it before seeing it.  I thought about building brackets for it, but I haven't had the time.
If we can talk Kreator into manufacturing a set of brackets that will bolt an XL7 front differential into a Sidekick, we will have many more steel differentials to choose from.
Offline kreator
  • 634
  • 15
« Reply #5 on: March 15, 2016, 09:46:15 AM »
Are all the XL7's housing the same ? I have an XL7 that I could pull the housing out of for a mock up
« Reply #6 on: March 15, 2016, 10:39:25 AM »
I will look for pics and post them again.  I don't think my old post is on the forum any longer.  I bought mine shortly after you beat me to the one you picked up a few years back.
« Reply #7 on: March 16, 2016, 03:28:05 AM »
You could always build your steel front diff out of a sami rear diff.  It is not going to break like the aluminum ones.  It didn't take that long convert mine, and now I have modified mine again to make it even better, it would use factory bearings and seals.  I even put a poly bushing in the passengers side improve seal life.
« Reply #8 on: March 19, 2016, 06:17:20 PM »
This is what the XL7 steel front differential looks like.
« Reply #9 on: March 19, 2016, 06:21:30 PM »
There are two very different XL-7 front differentials - the one pictured above is from an 03~06.
The front diff from an 01~03 XL-7 is very similar to that used on the GV and will interchange provided you use the matching third member "snout" mount with it.
Offline kreator
  • 634
  • 15
« Reply #10 on: March 20, 2016, 11:00:56 AM »
Ya the XL7 that I have is a 02 , I will have to find another 3rd housing as well
« Reply #11 on: March 27, 2016, 09:25:37 AM »
I have tried to make a rear mounts that come off the diff housing, extending it back to the cross member, and the forces on it are too much.  I was fortunate in that the mounts I made eventually broke, instead of bolts to the housing.  I ended up welding a duplicate mount to what is on the aluminum housing snout, Now I can use stock rear mounts.
There is a lot of force on that rear mount.
Offline Toys-n-Joys
  • 91
« Reply #13 on: August 07, 2019, 11:57:23 AM »
Does anyone have any more information on making your own steel front differential? Could you offset it to work like the calmini anvil? 2 of the same length axles?
« Reply #14 on: August 07, 2019, 07:04:47 PM »
Use the forum search (or google) to find brd hntr's posts - the conversion is documented in one of his threads - and since you're doing the conversion you get to offset it as you see fit.
