stock rim question
stock rim question
mike5721947
545
4
stock rim question
July 19, 2010, 07:37:15 PM »
ok, i ran some borrowed 31's on a club run a couple months ago and had them on stock steel tracker rims. i thought they were 15x7 but all the info i can find says different. im wondering if it is acually the same width as my rims i have that are 15x5.5 as that opens up alot more rims to me. i have a set of 31's to throw on the truck but i need another set of rims for them as i still need to run street tires.
ive read that some dodge ram and ford truck rims fit as well, but whats the backspacing?
31" kumhos 3inchs of lift.
wildgoody
8134
67
Re: stock rim question
July 19, 2010, 09:11:53 PM »
Yes, as long as the center hole is 105mm or 4-1/4" and the lug holes
are 5 on 5.5. As far as the backspacing the stock wheels are pretty
neutral, so probably half the rim width, but to be sure you need to
measure them on a case by case basis
Skyhiranger
3734
122
I don't buy, what I can build
July 20, 2010, 05:48:32 PM »
Most ford and dodge wheels are around 3.5"-4" backspacing. Most aftermarket wheels will be in that range too for backspacing.
BeercityTracker
40
Reply #3 on:
July 20, 2010, 09:33:00 PM »
here is a link to all the stock rims that will fit
http://www.zukiworld.com/forum/technical-discussion-beginner-repair/92-sidekick-rims/
beagle..t
1239
16
Reply #4 on:
July 25, 2010, 09:50:09 AM »
i thought that center bore hole had to be 108mm to fit ,
V6 swap auto ,2 dr ,2" BL,2" jeffs kit 512 gears warn hubs and 30/9.5/15 BFG AT
wildgoody
8134
67
Reply #5 on:
July 25, 2010, 10:11:24 AM »
4-1/4 inches is 108mm but the hole only has to be 105 for the front
hub to fit through, if I'm not wrong about the dimension, but I could
be wrong, I'm just going from memory
beagle..t
1239
16
Reply #6 on:
July 29, 2010, 05:42:04 PM »
np wild you r pretty much the guru on trackkick from what i have read
wildgoody
8134
67
Reply #7 on:
July 29, 2010, 07:27:43 PM »
Thank You, I'm wrong sometimes, but if someone says other
from what I thought the answer is, I go look it up to make sure
I got it right, still learning every day
