Strut mounts 02 Grand Vitra Anyone
JDMCRX
1110
02 Grand Vitra Pimp lol
May 07, 2005, 01:15:29 PM »
What did u guys do for the front strut mounts i got some ideas of what im gonna do but can anyone shed some light
01 GRAND VITARA
New project H27 in the GV goal 200 Wheel Horse Power JPB 1.75"front 2" rear Grand Vitra lifts
www.jbauto.ca
[/url]
Gear
112
Re: Strut mounts 02 Grand Vitra Anyone
May 07, 2005, 10:46:21 PM »
Don't touch them
Put in some OME struts, 40mm more travel then the stock struts and this is the limit of the front CV's unless you want to change them every few trips
Jeff
'03 Grand Vitara & '89 SWB Vitara
Blue bits, Locked bits, Missing bits
JDMCRX
1110
May 08, 2005, 12:55:35 AM »
Cause i was thinking of getting a set of Vitra upper strut mounts and flipping them like i did on my Tracker.
01 GRAND VITARA
www.jbauto.ca
[/url]
jagular7
1026
Jagular7
Reply #3 on:
May 08, 2005, 12:19:38 PM »
The US Vitara model has a much taller upper strut mount. I've got pics in my webshots under suspension......
http://community.webshots.com/photo/107940331/145071982RZIhBI
. There is a 1.5" difference between the Trackick and Vitara upper strut mounts.
Lenexa, KS
JDMCRX
1110
Reply #4 on:
May 08, 2005, 03:39:50 PM »
I measure mine from the base to the top were the nut goes 3" so the us ones are smaller then ours
01 GRAND VITARA
www.jbauto.ca
[/url]
JDMCRX
1110
Reply #5 on:
May 08, 2005, 03:42:38 PM »
I think what i may do is get a set of Vitra ones and cut the 3 puck flange off and weld them to the bottom of the OEM GV ones then burn the bushing out of the oem one so i can access the bolt on the Vitra ones
01 GRAND VITARA
www.jbauto.ca
[/url]
jagular7
1026
Jagular7
Reply #6 on:
May 09, 2005, 03:26:55 AM »
Similar to that, I'll end out with the same configuration. However, I'll be using a 1/4" flat plate between the upper mounts. With the flat plate, I can 'adjust' the space between the mounts for better droop.
Lenexa, KS
