suspension lift on a sj410??
  • 4756 Views
Offline Off-Road-King
  • 6
« on: August 10, 2003, 10:59:59 AM »
hi all...just wondering if anybody can sujest the best place to visit on the net that can supply a good but not costly suspension lift kit for my little sj410 suzzy ???.....the kind that comes with all the stuff in the kit(prop spacers,shocks,springs,bushes,etc)
i am only looking for about a 2" kit ...but if its good and cheap i might go a bit higher ;D
greatfull for any replys...(anythings worth a look)
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: suspension lift on a sj410??
« Reply #1 on: August 10, 2003, 11:58:04 AM »
go to zukiworld's home page and look at all the advertisers there on the right side of page...the best of the best advertise here from what i've seen...... ::)
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #2 on: August 12, 2003, 02:44:17 AM »
hooray another SJ410  8)  Dial 1 888 SAMURAI and ask them.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
  • 6
« Reply #3 on: August 13, 2003, 05:09:29 AM »
have had a look on the home page and i stil aint quite found what i'm looking for...they only really do big 3 to 5 inch lifts :'(
also i am from the uk so i cant i'n not sure what that number is that you said to ring ???..thanks for the sugestion tho
  • 6589
« Reply #4 on: August 14, 2003, 01:54:14 AM »
If you're looking for a smaller lift, CALMINI has the 2" kit that will fit the SJ410. It is the shackle reversal kit that puts the front shackle to the back of the front spring pack. We run this 2" lift on several Samurai around here with 235's and 29" tall tires and are sooper dooper happy. :) The phone number is 1 800 345 3305 but I'm not sure of the country code, is it 011?
here's a rig with this lift on:
http://www.zukiworld.com/month_020103/feature_gijane.htm
Old man emu springs could be an option as well. They cost a bit more and yield about a 2.5" to 3" lift. "A good buddy" :) is running this set up with 30" tall tires and it performs quite well. Contact Hawk Strictly Suzuki 888-SAMURAI or Rocky Road Outfitters 888-801-7271 for them.
Good luck, -Eric
  • 6
« Reply #5 on: August 14, 2003, 09:05:25 AM »
thanks...will check it out...not an easy thing this choice of lift...have read a lot of good and bad stories about different lifts...but again thanks for the help all
