Tracker w/ Sammi D-Train
  • 2076 Views
Offline mwracing
  • WooHoo!!!
« on: April 19, 2004, 09:04:16 AM »
Ok guys, been reading this bbs for a few weeks now and finally decided to join.  I had/have an 87 sammi that was recently rolled at Tellico and totalled the body.  I have since come across a 94 Tracker 2wd for free-if I do an engine swap for a guy.  So, I do the swap and now have a 94 efi Tracker.  I already have a fresh 1.6 carbed from the sammi, so I am thinking creative.  The sammi is awesome with the suspension mods, t-case, gears and lockers, and 4 wheel disc brakes.  Now, with that background, I am considering putting the whole drivetrain minus the transmission out of the sammi and into the tracker.  I am running 33-12.5 tires w/ 1" wheel spacers on the sammi.  Am I crazy for trying, or should I just put another sammi body on my capable frame?
  • 6602
  • 69
Re: Tracker w/ Sammi D-Train
« Reply #1 on: April 19, 2004, 09:38:04 AM »
I see two options either convert the 2wd tracker to 4wd using tracker parts (Front end goodies, transmission, and t-case). OR find a Samurai body to put on your Samurai frame. Personally, I wouldn't hybrid the two.
No matter which way you go, I'd suggest using the fuel injection off instead of the carb. You'll be happy with that decision.
Just my $.02
Good luck, Eric
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: April 19, 2004, 09:55:08 AM »
I agree with Eric.
Mike
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #3 on: April 19, 2004, 12:47:16 PM »
eric sounds like a smart guy. the sammi axles will be to narrow anyway.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
