Where to get custom R&P's
  • 9 Replies
  • 1613 Views
Offline blacknight
  • 987
    • Gonzookin
« on: January 15, 2007, 05:34:38 AM »
Looking for a little help with tring to find someplace that will make custom R&P's.  Why you ask I drive an XL-7 and short of replacing the rear their are not gears avable  :'(
Thanks,
George
Offline explosivo
  • 3157
Re: Where to get custom R&P's
« Reply #1 on: January 15, 2007, 07:58:19 AM »
It will probably be less expensive just to swap out the axle(s).
omghi2.us[/url]
Offline blacknight
  • 987
    • Gonzookin
« Reply #2 on: January 15, 2007, 12:37:45 PM »
well here the deal on that.  If I'm going to do the axle(s).  I might as well do it right which means something like a ford 9 all set up and locked is going to run $2000+.  If a R&P only runs me under $1000 I'm ahead.
George
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: January 15, 2007, 06:55:59 PM »
George
Are you running a 5-sp or automatic?
XL-7 front coils
1.5" rear coil spacers
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: January 15, 2007, 07:26:19 PM »
An automatic  :-[  if I had an 5sp man. I would just put 5.12's in it and call it a day.  The other thing I'm looking in to is an auto trans from an 05 or 06 xl-7. I was reading some place that they had lower gears in them and came with a 4.3 R&P.   Sooooo that trans and my 5.12's would gear me for just about 33's  ;D  Just still trying to find out if what I read was true.
George
« Last Edit: January 15, 2007, 07:59:50 PM by blacknight »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #5 on: January 15, 2007, 09:41:21 PM »
George
That's exactly what I was driving at.  You could swap in a 5sp, which came with the 4.3 r&p...  If I had another 1200 or so lying around, I'd do it.
XL-7 front coils
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #6 on: January 15, 2007, 11:40:19 PM »
The XL-7 5spd auto has 4.30 diffs like the manual while the 4spd auto got the 5.125 diffs. As you'll see the 5spd auto and manual have similar gear ratios.
Gear   4spd auto   4spd auto     5spd auto    5spd manual      5spd manual
               GV               XL-7             XL-7              XL-7                    GV
1st         2.830          2.452          3.520            3.830                  3.704
2nd        1.490          1.452          2.053            2.062                  2.020
3rd         1.000          1.000          1.401            1.436                  1.368
4th         0.690          0.689          1.000            1.000                  1.000
5th                            0.717          0.788                                       0.802
Diff         4.875          5.125          4.300            4.300                  4.300
Offline blacknight
  • 987
    • Gonzookin
« Reply #7 on: January 16, 2007, 06:15:12 AM »
yes but what year did they start with the lower gear Sean froom aftermarket had a 5sp auto and R&P was 5.12 then that was an 04.  So I'm guess when I 05 & 06 for the lower gears.
Also if I were to swap the trans what else needs to be swapped???
George
« Reply #8 on: January 16, 2007, 01:49:11 PM »
George
Wanna do soild axle Toyota swap with me at the same time?  Why fab twice?  I might even have an 85 toy donor we could get.  A couple grand would do the Kicker 2, R&Ps and lockers, and other stuff to boot.
just a thought.  Even with custom R&Ps, meez thinks they would be bookoo buckos.
And you'd still have no locker. :P
Offline blacknight
  • 987
    • Gonzookin
« Reply #9 on: January 16, 2007, 05:59:52 PM »
You know I would take you up on this if my XL wasn't a DD.  Which was another reson for the R&P.  But if a 05 trans fits with out to much fuss that may be the way to go.  Also on + side when I do go SAS gearing will be less of an issue.
George
