T/case double for Tracker/kick
  • 34 Replies
  • 6128 Views
Offline szabotage
  • 114
  • snaggletooth
Re: T/case double for Tracker/kick
« Reply #15 on: September 22, 2004, 09:30:10 AM »
I actually do the opposite when I wanna run in low. I use the sammi 4lo instead of the kick 4 lo.  reducing the gearing closer to the drive wheels will put less of a strain on all the parts before where the reduction is taking place.
the only thing I have to worry bout is the gearing in the pigs to suffer. shifting the kick into low, there's more of a chance that the sammi case and/or the diff will go
Offline szabotage
  • 114
  • snaggletooth
« Reply #16 on: September 22, 2004, 09:32:54 AM »
here's another link to the ghetto alternative to the OTT kicker kit if funds are tight
http://www.zookpower.ca/forums/showthread.php?t=1012
Offline explosivo
  • 3157
« Reply #17 on: September 22, 2004, 10:28:41 AM »
Which are you referring to, the one with the 2-part front DS or the one that lopped off the front output on the kick case?
omghi2.us[/url]
Offline szabotage
  • 114
  • snaggletooth
« Reply #18 on: September 22, 2004, 10:34:48 AM »
not sure what you mean by the 2 part front DS but yeah the lopped off kick case one
Offline explosivo
  • 3157
« Reply #19 on: September 22, 2004, 10:36:04 AM »
Post #3 in that thread... the driveshaft with a ujoint in the middle, mounted to the frame.
omghi2.us[/url]
Offline szabotage
  • 114
  • snaggletooth
« Reply #20 on: September 22, 2004, 10:41:38 AM »
oh yeah that's the shaeffer design, no I decided to lobb the front output on mine, I felt safer with a real driveshaft up in there
Offline explosivo
  • 3157
« Reply #21 on: September 22, 2004, 02:18:40 PM »
As would I. After school when I start on my kick project, hacking off the front output and sticking a sammy t-case behind my tracker is one of the things I wanna do... I'm waaaay to cheap to buy a kicker3 ;D
omghi2.us[/url]
Offline Bfunk
  • 406
« Reply #22 on: September 23, 2004, 12:37:12 PM »
I'm still curious how far the sammy case would stick down when mounted in a trackick?
Brian
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #23 on: September 23, 2004, 04:41:03 PM »
SOS RingR, Toy trans and cases.......................
Bulletproof and any gearing option off road or highway.
No chopped up trannys or t-cases and parts that are on the shelf, at NAPA or Autozone.......................................
Any gearing option for the highway?  ??? I thought Toy's were like a Kick with a 1:1 High that you couldn't change. What have I missed?
« Reply #24 on: September 23, 2004, 05:29:12 PM »
More info on Toyota T-case. say what?
Hooking up a Toyota T-case to Tracker Tranny or Toyota tranny and T-case to Tracker motor.
Or using a Toyota motor (god noooo) and all?
Tell me more. Inquiring minds want to know ;D
« Last Edit: September 23, 2004, 05:32:15 PM by trickker »
Offline explosivo
  • 3157
« Reply #25 on: September 24, 2004, 04:37:03 AM »
The goal of chopping up tcases is being cheap... that solution sounds more expensive than a kicker3 :o
How are the TORA axles coming along?
omghi2.us[/url]
Offline szabotage
  • 114
  • snaggletooth
« Reply #26 on: September 24, 2004, 09:17:46 AM »
definitely cheap, I figured it cost me under a hundred bucks Can. funds to get setup.
10 bucks in sawzallblades ( yes, i cut the front output off with a sawzall!)
10 bucks in aluminum plate
10 bucks in metal stapping and sq. tubing for the mounts
60 bucks to get it Tigged up
the rest was stuff I already had ( rubber bushings, nuts and bolts, mig welder etc.)
now that I think of it I did spend another 60 bucks on the 2"ID mechanical tube for the custom length front driveshaft, and a six pak of molson canadian to get the intermediate shaft welded. but still that's not too bad !
and I was able to use the front driveshaft to fit in the rear without modification, the sammi case sits about another 9 inches back from stock
here's closeup of my avatar pic, as you can see the sammi case doesn't sit too low(what you see sticking down is actually a bash guard  for the sammi case)
Offline explosivo
  • 3157
« Reply #27 on: September 24, 2004, 11:36:20 AM »
Man, I wish I could find a LWB Sammy down here... or even a Sammy :o
Where did you have it TIG'd shut at?
omghi2.us[/url]
Offline szabotage
  • 114
  • snaggletooth
« Reply #28 on: September 24, 2004, 12:00:39 PM »
I got the case tigged at a buddies shop here in Ottawa Canada (Alcon Welding), No pics, but the beads were super clean and seems to hold the oil in w/o leakage so I'm happy. I did have to pre-cut the plates myself though.
I had the intermediate shaft tigged as well but at another buddies shop and it was cheap (6 pak of beer)since he was only learning how to TIG. I had him fabb up three of em and they turned out true and solid (at least the one I'm using in the truck at the moment) haven't had to replace/test out the other 2 yet, so that's a good sign!
Offline szabotage
  • 114
  • snaggletooth
« Reply #29 on: September 24, 2004, 12:03:27 PM »
BTW I do have 2 more LWB's and one is 4 sale, but it is rough! (was saving it for parts)
