It's almost time for gears - what do I need
  • 9 Replies
  • 2115 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: July 31, 2005, 06:50:52 AM »
I heard some tcases dont work with the gear upgrades, I have a very worn 93 sunrunner and a good 91 tracker tcase, how do I know if I can do the 4.4:1 upgrade? I think trailtough still has the 4.4s for $649.   Also, I'm thinking of an auto locker for the back, will it work with the 93 diff and which is better, detroit or lockrite?  Auto locker for the front?
« Last Edit: July 31, 2005, 06:52:31 AM by bandit86 »
Re: It's almost time for gears - what do I need
« Reply #1 on: July 31, 2005, 02:04:34 PM »
I know the 93 T-case will work
not sure about the 91 tho
Loc-rite is good, just do the rear, an auto
locker in the front is tough on parts.
Detroit has a locker for the Track/Kicks ???
Or is it like the loc-rite ???
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #2 on: July 31, 2005, 03:16:00 PM »
 im getting at case from petroworks insted of trying to do it myself. go lickright in rear arb in frount. so you only use it when you need it or you will brake cv joints like crazzy.
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
Offline SnoFalls
  • 1358
« Reply #3 on: August 01, 2005, 10:48:29 AM »
The detriot is an "ez-locker" so essentially the same as the lockrite.
I'm running one of those lunchbox lockers in my front, beatin the rig pretty hard, and no breakage (yet!).
Offline bandit86
  • 1641
  • elv8rguy
« Reply #4 on: August 01, 2005, 12:29:37 PM »
WHats a lunch box locker?
Offline SnoFalls
  • 1358
« Reply #5 on: August 01, 2005, 01:00:54 PM »
locker that fits in the carrier (as opposed to replacing the carrier).
Offline bandit86
  • 1641
  • elv8rguy
« Reply #6 on: August 01, 2005, 03:10:14 PM »
sounds good.  is that what an auto locker is? or am I thinkig something else
Offline SnoFalls
  • 1358
« Reply #7 on: August 01, 2005, 04:01:45 PM »
Some lockers replace the ring gear carrier (e.g. ARB, full detroit, complete spool). Some fit inside the existing carrier (e.g. mini-spool, ezlocker, lockrite) ... since they latter "fit inside a carrier", they get referred to as "lunchbox".
Offline bandit86
  • 1641
  • elv8rguy
« Reply #8 on: August 01, 2005, 06:48:33 PM »
I see.  sounds like I need a lockrite for the front.. how is it at highspeed (lol) highway cornering?  does it ever lock up with the hubs engaged?  Just asking, cause in winter when it's 8 inches of snow on the highway, I like doing mach 3
Offline mrfuelish
  • 2862
« Reply #9 on: August 01, 2005, 10:52:38 PM »
they take a bit of getting used to on ice,snow or deep snow no prob,I would get an arb in the rear and loc-rite in the front and just do two wheel drive if you have studs.
