The biggest tire you can fit on a Samurai with a S/R 3.5 lift???
  • 20 Replies
  • 8935 Views
Offline MiniFJ
  • 99
  • Sami's are like potato chips...can't have just one
What size tires are you guys running with this size lift?
Right now I'm running 29x8.5 swampers on some plain steel mods. I'm needing/wanting a larger tires because it's a little to over geared right now. I prefer a swampers and I don't mind trimming to make them fit but how big is too big on that lift?
I was thinking of 31x9.5 or 31x11.5 on 15x8 alum rims. Any help would be great!!!!!
« Last Edit: March 26, 2009, 02:33:51 PM by MiniFJ »
88.5 Samurai TinTop, 1.6 w/ DT header, 3.5 Calmini S/R Kit, 30" Cooper STT
Re: The biggest tire you can fit on a Samurai with a S/R 3.5 lift???
« Reply #1 on: March 26, 2009, 02:12:41 PM »
can you post some pics of your rig with the 29's I want to see what it looks like with the SR and those size tires.
« Reply #2 on: March 26, 2009, 02:13:26 PM »
If stock is 27", and you're adding 3.5" to that.... I'd think you'd be fine. Since the lift only needs to be 1/2 the increase in tire height (radius from the axle to outside of tire is 1/2 the tire height increase).
Offline MiniFJ
  • 99
« Reply #3 on: March 26, 2009, 03:00:21 PM »
My icon is my samurai at Powerfest, it's small but I'll get a better picture out to you tonight. I love the 29's but with the gears, the high rpms down the freeway are a little much for my liking.
I was thinking 31's would fit with some timming but will a 31x11.5 rub on the inside wheel wells and leaf spring lock to lock?
« Reply #4 on: March 26, 2009, 03:28:31 PM »
What? too much gearing? Try 30's with 6-1's.
Offline MiniFJ
  • 99
« Reply #5 on: March 26, 2009, 03:31:32 PM »
WOW!! What are your rpms at 60 down the freeway??!!
« Reply #6 on: March 26, 2009, 03:36:36 PM »
About 4200. You have seen my car before.
Offline MiniFJ
  • 99
« Reply #7 on: March 26, 2009, 03:42:05 PM »
I just didn't know or remember you were rocking a 6:1 t case!! Compared to your rig my 3600rpm at 60 is nothing!! hahahaha.
  • 6593
« Reply #8 on: March 26, 2009, 03:48:40 PM »
That type of rpm/mph is almost stock. You're not driving a big V8 or a diesel, right? These are small ring-a-ding-ding engines. They'll do 4,000 - 4,500 all day long no problem. My green Samurai with the 30" tires runs 4,000 at 60 and my ol' red one runs 4,300 at 60. Both of them have logged several thousands of miles at those types of rpm.
You may be OK where you're at! :)
Offline MiniFJ
  • 99
« Reply #9 on: March 26, 2009, 04:01:43 PM »
I guess a small ring-a-ding-ding engine can handle 3600rpm and up but I would like to do 65-70 at 3600 rpm. I think I have the enough power to step up the tire size and knock off a few rpms on freeway.
Sooooo do you think 31x11.5's would fit on my samurai with 3.5 of lift?
« Last Edit: March 26, 2009, 04:28:47 PM by MiniFJ »
Offline norcalwreckchaser
  • 128
    • www.norcalwreckchasers.ning.com
« Reply #10 on: March 26, 2009, 04:06:18 PM »
Are you still running spring under axle, I have a 5" Calmini S/R, I recently ditched the S/R in favor or standard 2" shackle's and I rub 30X11.50 TSL/SX's even with some trimming to the rear of the fenders.
Norcal
86' Samurai, 5" spua lift, rear missing links, 4.57 gears, 4 to 1 Transfer Case, Lockrights F/R, ARB Front bumper, Doug Thorley Header, Rock Rails, GM alt. swap and other Misc. goodies.
Sold 7/10 :(
Offline MiniFJ
  • 99
« Reply #11 on: March 26, 2009, 04:31:41 PM »
So it's the width that is the killer. Does the tire hit the leaf spring lock to lock at all and how much did you need to cut out of the front by the bumper/support to run 11.5's?
« Reply #12 on: March 26, 2009, 04:57:01 PM »
Yeah it's really not that bad, just a little loud. I have a custom/stock front bumper that mounts off the frame. The stock tube mounts are cut off.
Offline MiniFJ
  • 99
« Reply #13 on: March 26, 2009, 05:02:30 PM »
That does not sound that bad. I can handled some cutting and a little rubbing!!
Now does anyone have some good used 31 inch swampers for sale!! hahahahaha
  • 128
« Reply #14 on: March 26, 2009, 05:50:28 PM »
I have an ARB front bumper and original bumper mounts/tubes are long gone, most of my trimming of the fender was the "lip" under the fender flair. I did rub in the same place with 30X9.50's on 15X7 wheels.
Sold 7/10 :(
