Ticking all of a sudden
  • 20 Replies
  • 4439 Views
Offline essjay
  • 133
« on: July 25, 2009, 09:19:26 PM »
Hi all, wondered what might cause the valves to all of a sudden start ticking,  I have had the sammy for a month now, I changed the oil when I first got it with mobile one high mileage, no tick, then a couple days ago, all of a sudden, started ticking, I checked the oil level and it was on the bottom mark, so, since it was ticking I added 3/4 quart of lucas, now it ticks mostly, but once it didnt. I am confused.  Should I just adjust the valve lashing?  To be honest I am afraid to screw with the timing belt, with the threats of the keyway issue, I will be screwed if thats out.
Thanks people.
Offline essjay
  • 133
Re: Ticking all of a sudden
« Reply #1 on: July 26, 2009, 11:57:43 PM »
OK, I did some checking, cant tell where the sound is coming from till I get one of those mechanics stethescopes (sp?) btw Harbor Freight has them for like 3 bucks if anyone wants one.
the sound does not get louder or more defined if you take the oil filler cap off.  I did on the other hand notice, a 1mm or less, wobble in the lower pulley, so I guess Ima have to tear that apart.
SO what all should I get? Autozone has a timing belt kit, but is vague about what is included, says "Recommended replacement: kit includes new belt and all new tensioners and/or idlers for the application" Im guessing its the timing belt and the tensioner, the belt is $13 by itself and the kit is 76 so what the hell else comes with it? I will call tomorrow and find out if no one knows.
I am also gonna get a waterpump and gasket. what else do I need to get? I am going to have to deal with this keyway issue also.  We should compile a list of materials for this, then make a new post, and sticky it, cuz everytime I do a search I end up with 10 tabs up , and I just get confused.
hopefully its not too worn out, I spent all the money I had on this damn sammy, then lost my job.  Think a 1mm wobble is still okay?
Where else could the ticking be coming from?
Sorry for bombarding you with these questions, but I went from a new car to a 23 year old vehicle, I am pretty inclined, but have no knowledge of sammys.
Thanks again
« Reply #2 on: July 27, 2009, 06:04:24 AM »
I'd check the keyway first and then check the valve lash.
Offline essjay
  • 133
« Reply #3 on: July 27, 2009, 06:45:33 AM »
heres my problem, I need to know everything Im going to need to fix the keyway before I start working on it, because once I tear it apart, I will be alone stuck 30 miles from anything, and its my only transpo.
should I do JB weld? do you know which locktite to use? am I going to need a pulley puller? things like that.  Thats why I said it would be nice to have a list of items, so that in the future, anyone could just look here and get a good idea of what is needed before they disconnect their crankshaft, pretty much. lol
Thanks for your help
Offline Jookycola
  • 372
« Reply #4 on: July 27, 2009, 10:34:43 AM »
My sammy did that too once.  It was fixed when i performed a valve adjustment.  I'd try that first.
  [/url]
Offline essjay
  • 133
« Reply #5 on: July 27, 2009, 10:43:18 AM »
question is, should a less than one mm wobble warrant me tearing that all apart and fixing it now, is it gonna get worse quickly, or years down the road?
I plan on adjusting the valves, thanks for your response.
I can fix the pulley now if I need to, but dont want to have to spend anymore than I need to.
Offline sammypro.com
  • 153
« Reply #6 on: July 27, 2009, 04:57:32 PM »
the pully is held on by (4) 10 mm bolts. Not sure how you have a wobble there unless you have a wobble in the lower crank gear ( held on by the 17mm bolt) the pully and the lower gear are seperate from one another. The only way to "fix" the key way is to replace the crank or have it welded if in fact it is screwed up. The lower gear and the pulley are much easier to replace if you can isolate the problem to one or the other component. Look for a larger than normal groove in the lower crank pulley, smaller than normal key, stuff like that. Hope that helps
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some freakin' muscle.
http://www.facebook.com/#!/sammypro
Offline purpletracker
  • 115
« Reply #7 on: July 27, 2009, 05:17:38 PM »
what 's your oil pressure at?
Offline essjay
  • 133
« Reply #8 on: July 27, 2009, 08:04:14 PM »
dont know, has no gauge, hopefully it has a warning light.
« Reply #9 on: July 28, 2009, 05:39:12 AM »
I would suggest taking a close look at that lower pulley - the wobble is most likely the accessory pulley loose on the timing belt pulley, but if it's not, then it'll be a problem with the key and that is better fixed sooner rather than later, because it will get worse and rapidly.
It's going to be almost impossible to give you a list of what it'll take to fix it, without knowing how bad it is - the key is damaged for sure, the crank could be damaged, the pulley could be damaged - what happens is the center bolt loosens and allows the pulley to rotate slightly, usually there is no visible wobble, so if you are seeing a wobble, and it is not the four bolts loose, yours is far gone and you'll probably need some machine shop work on the crank and a replacement timing pulley & key.
« Reply #10 on: July 28, 2009, 07:23:32 AM »
FI?
If so, how is your idle?
Offline essjay
  • 133
« Reply #11 on: July 28, 2009, 09:32:51 AM »
no its a 1.3 8v carb sammy
man I hope its "half ass" fixable, I am done if i need to replace the crank.  why cant you just set things in place, timed correctly, and weld/ jb weld it all? I mean motors got 130k on it, it runs great, but realistically, if something major goes out after changing the water pump and anything else I can get to when I take it apart, it will be time for anew engine anyway.
what all can I get to back there? oil pump prob
oh btw, if I do find out its just the pulley bolts, should I just leave the crank bolt alone? does this only happen when some slacker uses the easy way out, or does it happen eventually anyway?
« Last Edit: July 28, 2009, 09:43:33 AM by essjay »
« Reply #12 on: July 28, 2009, 01:42:14 PM »
Exactly!!  if you weld/jbweld it and there are any problems with oil pump or the front end seal you've had it.
And yes - if it's the pulley bolts just tighten them and leave the crank bolt alone
Offline captchee
  • 224
« Reply #13 on: July 28, 2009, 09:04:25 PM »
 you dont need a scope . all you need is sometning solid .
 on old chevy engins we would use  the dipstick .. however it doesnt work real well  with a suzuki stick .
 but all you need is a metal rod or tube .  even a big long screw driver will do . just stick one end up against your ear  and the other in the area you want to hear  whats going on.
 doing that you will be able to tell if its the lifters , which lifter . hold it below the head and  on a cylinder and you will hear if a wrist pin is ticking . down on the bottom and on a Cylinder  and you will here if its a rod bearing going . no need for a scope
Offline essjay
  • 133
« Reply #14 on: July 28, 2009, 10:12:09 PM »
Yeah but its an excuse to go to harbor freight and get one
