stronger cv's
  • 884 Views
Offline museboy07
  • 641
stronger cv's
« on: May 30, 2007, 06:20:44 PM »
I'm lookin for a stronger cv shaft/joints that can be used at a higher angle.  I want as much ground clearance as i can get without dropping the diff or swapping over to a solid axle.  Any help/links of this would be great...thanks!
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: stronger cv's
« Reply #1 on: May 30, 2007, 09:17:13 PM »
Now that's a tough list of requirements.  The best bet is to probably use something similar to the calmini anvil so you can use 2 x driver side cv shafts instead of the passenger...
The other option is toyota cv's, but i don't really know much about that.
1993 4-door Sidekick
4.24:1 t-case
Offline MKOLSEN22
  • 217
  • Come on 32's
Re: stronger cv's
« Reply #2 on: May 30, 2007, 09:20:55 PM »
Talk with your local machinist/sandrail builder and figure out how to run some 930 or 934 CV's!!  This has been talked about from time to time but I don't think I have ever seen it done yet.  If it has been done I haven't seen the write up for it.
Not saying that it hasn't been done, I just haven't seen it yet.
Start the chant.
Do it!  Do it!!  Do it!!!  Do it!!!!  Do it!!!!!  Do it!!!!!!
