Pro's and Con's
  • 1054 Views
phloop
Pro's and Con's
« on: October 03, 2008, 08:21:05 PM »
Whats the thought on the RPM range of a cam? My junk has 4.16's, 5.12's, and soon to be 33" TSL's. Putting in a 1.6 8V with a MS2/44mm. Don't do a lot of crawling, more trails and mud.
The question is, go with the low range cam where the cam is used up early or go with a cam that comes on later?
PS, I can't spell worth a danged.
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Pro's and Con's
« Reply #1 on: October 03, 2008, 08:53:01 PM »
If you are running in mud and such I would go with a higher RPM cam. More rpm means more wheel speed which is better for mud.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Amilla
  • 1076
Re: Pro's and Con's
« Reply #2 on: October 04, 2008, 05:52:04 PM »
What RPM do you find yourself using the most?
The 1.6's seem to like the high revs, i would probably go with the 2200 to 5500 cam.
Amilla
