Tips on replacing front coil spring
  • 13 Replies
  • 3483 Views
Offline blacknight
  • 987
    • Gonzookin
« on: April 12, 2005, 07:48:01 AM »
Anyone have any tips on replacing the front springs on a Calmini kit for kick? I was thinking that I might be able to just unbult the the ball joints from the bottom of the  controll arms.  Then I could just swing it down and drop the spring out.  or am I going to have the do this pain in the |removethispart|@$$ way and unbolt all the other stuff???
George
Re: Tips on replacing front coil spring
« Reply #1 on: April 12, 2005, 07:51:15 AM »
I just remove the circlip from the driveshaft, remove the bolts from the lower strut mountings and drop the wishbone down. You might have to remove the sway bar if you still have it fitted. You'll need to make sure you don't overextend the brake lines too.
Offline chet
  • 556
  • Zuki time!
« Reply #2 on: April 12, 2005, 08:37:39 AM »
I looked at doing it the way you suggest but it was  a pain so I did the normal way.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #3 on: April 14, 2005, 12:58:32 AM »
George
This is the way I've always done it.  Good luck
96 Tracker
32 MTR's Warn 8000i
Offline SnoFalls
  • 1358
« Reply #4 on: April 14, 2005, 03:02:57 AM »
If you haven;t already, ditch the sway bar.
I disconnect the strut at the top, compress the arm with a jack, pull the 3 bolts from the ball joint, lower the arm, and out comes the spring.
Offline blacknight
  • 987
    • Gonzookin
« Reply #5 on: April 14, 2005, 06:14:37 AM »
Why unbolt the strut.  If I unbolt the ball joint the only thing atteched to the control arm would be the spring and sway bar. The strut would hold all the other stuff up and some what out of the way.
George
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #6 on: April 14, 2005, 03:39:51 PM »
I personally just unbolt the 3 balljoint bolts.  :-/ It is a pain to reallign but Ive done enough that Im kinda used to it.
Mike
Offline SnoFalls
  • 1358
« Reply #7 on: April 15, 2005, 06:53:42 AM »
I only unbolt the strut to make it easier to get the ball joint out from under the arm. Not a necessity, just makes a little easier IMO.
Offline blacknight
  • 987
    • Gonzookin
« Reply #8 on: April 15, 2005, 09:46:53 AM »
I will keep that in mind if it give me a hard time this weekend.
George
« Reply #9 on: April 15, 2005, 10:03:51 AM »
I unbolt the bottom of the strut rather than the balljoint as it is one fewer bolt and I find that having the jack under the wishbone gets in the way
Offline mahimahimo
  • 377
« Reply #10 on: April 16, 2005, 07:18:27 PM »
after readen all this 2 questions .....which is the easiest way...and y is it good to get rid of the sway bar....thanx
                                             -mo
« Reply #11 on: April 17, 2005, 04:37:48 AM »
                                           -mo
This is the easiest way and I've also done this way.
Mike
And for the sway bar. Unbolting it will give you more flex than with it. The sway bar will try and keep the wheels at the same height and not allow one to dip or compress without the other one doing the exact same.
But thats my story and I'm sticking to it. ;D
Offline mahimahimo
  • 377
« Reply #12 on: April 17, 2005, 01:53:18 PM »
aight thanx...now i can finally get my spacers in ...hopefully tom ..how do u alighn that ball joint ...and how hard is it ...
                                            -mo
« Reply #13 on: April 17, 2005, 03:18:10 PM »
                                            -mo
THere is really no allignning it. Its just getting the 3 bolt holes to line back up. Just make sure the Jack is in a good spot (sometimes you gotta reposition the jack)where it won't slip off and not in the way.
Just remember the Spring is under compression adn it will jump out if givin half a chance.
