Average you've paid 4 Clutch job
  • 1204 Views
Offline Jookycola
  • 372
« on: December 13, 2006, 11:56:44 AM »
so my Tranny makes a winding noise in 1st, 2nd, and 3rd gear.  I changed the fluid and it's still noisy.  I was told by people at work (we build race cars) that it sounds like the Throw-out bearing may be going.  So a "clutch job" may be in my very near future.
I'm just wondering what you all have paid for a clutch job.  just to gauge how hard i'm going to get hit.
  [/url]
Offline mrfuelish
  • 2862
Re: Average you've paid 4 Clutch job
« Reply #1 on: December 13, 2006, 01:44:42 PM »
It's your trans bearings.
Offline mlovetripp0
  • 204
  • do more with less
« Reply #2 on: December 13, 2006, 04:19:16 PM »
how hard is it to change the tranny bearings?
87 sammi
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #3 on: December 13, 2006, 04:35:58 PM »
If it's fairly quiet in 4th, it would be the tranny bearings.  Try to find a good used or rebuilt if you can't rebuild. Changing out a transmission/changing a clutch is pretty easy on a sammy. Give youself a good day or two if you've never done one. You should be able to do one in less than 8 hours. That allows for dropping shafts, and exhaust and cleanning everything up. You may encounter some rusty bolts on the exhaust like I did. I could probably do a full swap now in less than 4 hours. Of course I'm kind of slow at it (I think.)
Another thing you might try (it helped mine) is throw in a quart or so of lucas. Don't use the lucas for trannys because I think it says for automatics.  I used the same stuff you use in the engine. It says on the bottle it's for manual transmissions (in the fine print). It quieted mine down quite a bit but I think it may have made it harder to shift when the tranny was cold.
-Adam
If all criminals were behind bars, there would be no one left to patrol the streets.
86 Samurai Tin-Top stock with a Harley 44 sidedraft carb
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: December 13, 2006, 04:46:06 PM »
Its the bottom lower bearing. Its not that difficult. If you can put a 4to1 in the Tcase this will be easier. The bearing is around $20 from suzuki. If you continue to drive it it will take out other bearings.
Mike
