GV at Portland Wrecking yard
  • 2931 Views
Offline aveatr1
  • 48
« on: May 03, 2011, 08:10:12 AM »
Hey everybody,
Went to the Pick and Pull in Tualatin ( south of Portland) they have a 99 Suzuki GV that has been rolled.  All the undercarriage is still there and looks to be in good shape.  I don't know if the front diff will fit my 92 Tracker, but if any one else knows it is out there for the taking.  Just thought someone might be interested.
Joe
Re: GV at Portland Wrecking yard
« Reply #1 on: May 03, 2011, 02:38:41 PM »
I believe most people would prefer to put the 92 Tracker front diff on the 99 GV, rather than the other way around - 99~05 have a pneumatic free wheel mechanism inside the front diff that is ocassionally problematic, and the 99's also have a few other issues with oil levels and leaking seals.
Offline Thirty-Nine
  • 286
    • Subcompact Culture
« Reply #2 on: May 04, 2011, 03:21:30 PM »
Do you remember which wheels it had on it, by chance?
Offline blacktrack99
  • 254
« Reply #3 on: May 04, 2011, 04:08:07 PM »
The most coveted piece (if it has it) is a steel front diff housing that'll let you run Calmini's Anvil.  Some are aluminum; so, you have to check.
« Reply #4 on: May 05, 2011, 08:59:36 AM »
« Last Edit: May 08, 2011, 10:50:30 AM by fordem »
Offline aveatr1
  • 48
« Reply #5 on: May 09, 2011, 03:49:37 PM »
I remember the wheels as aluminum, I think they were torn up from the wreck though.
Thanks guys, I wasn't sure if that steel fron diff housing is what people wanted for the strength.
