Some things on the board aren't working!
  • 11 Replies
  • 2001 Views
Offline Cwkick
  • 888
« on: July 11, 2005, 12:14:43 PM »
PM's!  I can't send one.
I can't change my avitar.  I can change other things in my profile.
Anyone else having problems??
Cwkick
Offline SnoFalls
  • 1358
Re: Some things on the board aren't working!
« Reply #1 on: July 11, 2005, 01:11:41 PM »
Sounds like $DOCUMENT_ROOT/images/avatars wasn't set 0755 ...
Offline LawDog
  • 531
  • Lakeview Motor Sports' Makin it Hert! Tell u whut!
    • Emerling Chevrolet
« Reply #2 on: July 11, 2005, 01:14:56 PM »
??? ??? ??? I could've sworn it was dot-egg or maybe dot-muffin 8)
"I'm the Law 'round here" said the Duckshirt.
Get a Zuk, Get it dirty, Git-R-Done!!
At Lakeview Motor Sports we specialize in rediculousness, hackdome, and wasting your time.
Offline SnoFalls
  • 1358
« Reply #3 on: July 11, 2005, 01:43:29 PM »
I'm just trying to help eric out ... phpbb is probably a new thing to him and has it's necessities.
Offline explosivo
  • 3157
« Reply #4 on: July 11, 2005, 08:08:14 PM »
But this isn't phpBB, it's SMF ;)
omghi2.us[/url]
  • 6603
  • 69
« Reply #5 on: July 12, 2005, 06:37:08 AM »
Ok,
I know there are a couple things so far that aren't working.
A. SMTP needs set (this is causing an error whenever anyone wants/needs email sent)
B. The .gif for Mark Unread is missing
Are there any others? Please don't tell me you don't like this or that or this needs tweeked. Just post here with issues that relate to a broken part of the forum and I'll try to get them fixed right away.
Thanks for your help, Eric
Offline SnoFalls
  • 1358
« Reply #6 on: July 12, 2005, 07:43:52 AM »
whoops you're right ... never looked at the copyright down below  :-X
Offline explosivo
  • 3157
« Reply #7 on: July 12, 2005, 09:46:15 AM »
I don't care for the way large images are handled to prevent table stretching... but that's less of a problem and more of a personal annoyance. :-/
omghi2.us[/url]
Offline scottmaxx
« Reply #8 on: July 12, 2005, 04:03:23 PM »
since this new format showed up i cant log in on my old user name.
if i use the password reminder it says my username does not exist.........
if i try to register using my old username it tells me that name is in use by another member???
WTF is happening??
i had to create a new name AND use another email address as it would not accept either of my old details??
any ideas??
Offline scottmaxx
« Reply #9 on: July 12, 2005, 04:04:27 PM »
and i get this error message after every post?
An Error Has Occurred!
mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set()
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #10 on: July 12, 2005, 10:50:14 PM »
Me too! The posts always shows up when I check but I can't delete a post if I try.
  • 6603
  • 69
« Reply #11 on: July 13, 2005, 06:50:34 AM »
Ok, please PM me with any further problems. As stated above, the email problem or SMTP issue is being worked on and that will fix a lot of these problems.
