TOYOTA IFS here i come...
  • 28 Replies
  • 14489 Views
Offline barcus
  • 97
  • fun
« on: September 25, 2005, 12:25:10 AM »
after reading some of the posts (particularly "toyota ifs, paging mr. hagen) i decided to swap my axles with that of toyota. i'm from philippines so the donnor here is a hilux.
my goals are to strengthen my axles, my 3rd member and to correct my final drive ratio. i already broke 4 aluminium housings and a cv so i guess its about time i do something. also with 5.83s no longer available, the hilux's 5.71s should do the trick.
i have some questions and i hope you gurus here can offer some advice. thank you guys in advance...
1. from what i gathered i will be using suzuki spindles together with the toyota axles and lockouts but the toyota lockouts doesnt quite fit into the suzuki spindle. what modifications should i do here?
2. the front assembly i got comes with automatic locking hubs. do i have to use manual locking hubs or will these do?
3. instead of hub spacers (since the axles are longer than the spindle), i might have the axles machined. are there any downside to this?
these are the questions for now. i hope to here from you guys soon. will also be posting some pics in the future. thanks.
Offline explosivo
  • 3157
Re: TOYOTA IFS here i come...
« Reply #1 on: September 25, 2005, 05:50:43 AM »
Even if you have teh shafts machined down, you still have to deal with the issue of an adapter to bolt the hub onto the Trackick knuckle.
Talk to 37kicker, as I believe he's the guy who sold Bobzooki the spacers and various junk he neded to install Toyota CVs. Of course you're still gonna have to deal with making mounting bracketry for the Toyota diff, as his kit is just to put the shafts on a Trackick diff.
Over on the Pirate4x4.com forum there was a thread about someone swapping in the whole IFS drivetrain out of a Toy and into a Sidekick, but I can't find it right now.
omghi2.us[/url]
Offline 1bigtracker
  • 3409
« Reply #2 on: September 25, 2005, 06:51:29 AM »
http://www.pirate4x4.com/forum/showthread.php?t=318480
Stu
Offline barcus
  • 97
  • fun
« Reply #3 on: September 25, 2005, 08:37:02 PM »
was able to comunicate with that guy from pirate4x4. he only installed the toy diff (w/ suzuki axles). i believe i might be the first guy who's crazy enough to swap the whole drivetrain.  ;D
Offline Hawklin
  • 109
  • If it cant be fixed with Duck Tape it aint broke
« Reply #4 on: September 26, 2005, 12:44:23 AM »
Heh well let me know how it goes my plans, as soon as money allows will be swapping both axles from a 90 toy v-6 truck and using t-100 axles for added length and fabbing new a-arms and using the toy knuckels and brake components.  Was hoping to get started this winter but when you get started on it keep us informed. ;D
Rob Cross
90 Tracker (sold :()
91 Toyota 4x4 bone stock other than a redneck lift(cranked T bars and a block in the rear) on 35's
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #5 on: September 26, 2005, 11:33:17 AM »
I would go with stock manual or  full time pucks  save the cone lock out washers . the down side is when you break you need to have another one made.  stan
Offline barcus
  • 97
  • fun
« Reply #6 on: October 02, 2005, 11:48:53 PM »
got my hubs machined...
... and new brass bushings fitted...
... will start my swap soon...  ;D
Offline barcus
  • 97
  • fun
« Reply #7 on: October 03, 2005, 09:33:52 PM »
toy axle mated onto the zuk hub...
there is a 4cm gap between the lockout and the hub. is it possible for someone to post a photo of the spacer?
also the toy lockout flange doesnt quite fit into the groove of the zuk spindle. is this critical? will manual lockouts solve this problem?
(toy spindle on left, escudo on right)
thanks guys...
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #8 on: November 14, 2005, 06:53:30 AM »
Barcus any updates on this? You finished it allready or still building?  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
« Reply #9 on: November 14, 2005, 08:19:50 AM »
Looks like its getting there at least
http://www.zukiworld.com/forum/index.php?topic=9444.0
Offline barcus
  • 97
  • fun
« Reply #10 on: November 15, 2005, 08:11:35 AM »
fabricated my locking hub spacers
Offline barcus
  • 97
  • fun
« Reply #11 on: November 15, 2005, 08:19:12 AM »
... and axle spacers for a widen front end (hagen)...
Offline barcus
  • 97
  • fun
« Reply #12 on: November 15, 2005, 08:29:10 AM »
some pics of hangers
front
driver side
carrier (notice i relocated the calmini steering stab to make room)
Offline barcus
  • 97
  • fun
« Reply #13 on: November 15, 2005, 08:31:07 AM »
front end...
Offline barcus
  • 97
  • fun
« Reply #14 on: November 15, 2005, 08:38:50 AM »
rear toy axle with zuk spring cups, shock mounts and trailing arm mounts
rotated (hagen)
had the hubs machined to 5 studs
